Ansys and Openfoam Simulation
Like Tree1Likes
  • 1 Post By checasino
Old   November 13, 2023, 05:54
Post Ansys and Openfoam Simulation
Silvia Sambuca
checasino is on a distinguished road
Hy everybody,
I am simulating a turbulent airflow flowing in a bypass tube of circular diameter of 0.07 m from a condition of 300 Pa in the inlet and ambient pressure in the outlet (so only pressures are known). I created the mesh (I am attaching an image in here) in ANSYS mantaining a y+ of around 30 (calculated on the target velocity that I would like to reach).
The mesh obtained is quite regular. Then I exported the mesh so that I could use both Ansys (Fluent) calculation and Openfoam. I will attach also the boundary conditions for both solvers.
Finally I tried to mantain same/similar schemes for both solvers: steady solvers and second order schemes for both, same convergence criteria (1e-6) and relaxation parameters (p/k/epsilon 0.4 and U 0.5).
First of all the simulation on Ansys is converging, instead Openfoam not (even though residuals are around 1e-5 at very high iteration number). Even though the values of pressure are comparable (remembering that values of P are in m2/s2 in Openfoam), the values of velocity and so flowrate are very different (0.0450 m3/s in Openfoam and 0.0539 in Ansys). Can somebody explain why these values are so different ?
B.C.Ansys.zip
B.C.Openfoam.zip
Notice that the values of 122 m2/s2 in Openfoam was defined after a first simulation in Ansys, that gave 122 m2/s2 as the value of the static pressure.
aerosayan likes this.
checasino is offline   Reply With Quote
ansys, openfoam, tube flow
[Other] Ansys Fluent to OpenFOAM silver.blaze OpenFOAM Meshing & Mesh Conversion 2 July 27, 2022 09:32
[Commercial meshers] Moving mesh from Ansys to OpenFOAM MFWilliams OpenFOAM Meshing & Mesh Conversion 0 December 13, 2021 06:43
ANSYS fluent and OpenFoAM comparison gentodin Main CFD Forum 6 February 26, 2021 04:58
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
OpenFOAm solver, ANSYS post processing achinta OpenFOAM 3 May 13, 2010 03:54
