November 8, 2023, 08:06 |
Is this residual reasonable?
Rep Power: 6 |
I am working on an unsteady simulation of vehicle aerodynamics. I used sst-kw turbulence model and coupled flow solver. I found that the residuals have a rising tendency as the simulation goes on(attached figure 1). The residuals in each time step can drop by 3 orders of magnitude to 10E-4~-5(figure 2). No divergence occurred. Is this a reasonable residual? And what might be the cause of the overall rising residuals? Looking forward to your professional advice. Thank you! |
November 8, 2023, 13:38 |
Arjun
Rep Power: 34 |
Yes this can happen.
"And what might be the cause of the overall rising residuals?" As the flow is converging the yplus, shear etc are changing at the walls and this is what most probably causing this behaviour. Or some sort of limiting inside that is causing this non smooth behaviour. |
convergence criteria, residuals going up., residuals. |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
