CFD validation test
Like Tree3Likes
  • 2 Post By aerosayan
  • 1 Post By LuckyTran
Old   November 2, 2023, 21:38
Default CFD validation test
Dahae Seong
dseong is on a distinguished road
Hi all,
I just want to ask a general question about the CFD validation.
I thought that I needed to do a validation test when I changed my geometry (e.g. add or remove tables/partitions). However, I have seen some research papers using their updated geometry without any additional validation test.
I am wondering how I can confidently say my geometry is experimentally validated. If I add some partitions to my validated geometry and complete the mesh independence test, then can I say that my model is validated without an additional validation test? Are there any criteria/standards?
Thanks!
dseong is offline   Reply With Quote
Old   November 2, 2023, 22:43
Sayan Bhattacharjee
aerosayan is on a distinguished road
The idea behind mesh independence study is to identify if refining/coarsening your mesh has any effect on your solution.
It doesn't actually prove that your solution is correct. It simply proves that the solution doesn't change when you refine/coarsen a mesh.
Some researchers don't need to do mesh independence study because even on a coarse mesh, their results agree with the experimental/analytical results.
So, they can claim accurately that their solution is correct.
So, before mesh independence study, you should probably find an experimental/analytical results with which you can verify if your solution is correct.
One of my favorite test cases is shockwave over a wedge. It has both an analytical and experimental solution, and to save time, sometimes I run the simulation at a very coarse mesh to just verify if our shock angle is correct in the result, and if the density is changing correctly.
arjun and dseong like this.
aerosayan is offline   Reply With Quote
Old   November 3, 2023, 00:20
Dahae Seong
Thanks for your explanation!
Quick additional question,
If I have a simple room geometry which is already completed the experimental validation test and mesh independence test. And now I want to add some tables in this room geom. In this case, do I need to do additional validation experiments with tables? Or am I okay just working on the mesh independence test?
Old   November 3, 2023, 01:12
Lucky
Mesh independence is never a validation.
What if instead of a table, there is an elephant in the room? Your CFD of a room is not representative of a room of elephants and you eventually will need to validate it for elephants.
dseong likes this.
Old   November 3, 2023, 01:26
Dahae Seong
Thanks! Now, it is very clear to me.
ansys fluent, validations
[OpenFOAM.com] Installing on Ubuntu 18.04 samiam1000 OpenFOAM Installation 11 April 27, 2020 01:01
[OpenFOAM.com] Issue configuring ./makeParaView - Ubuntu 16.04 bjdarrer OpenFOAM Installation 2 April 20, 2020 14:50
Inhouse CFD code validation Zato_Ichi Main CFD Forum 0 August 12, 2016 09:54
Validation examples to test my CFD code Roddy Main CFD Forum 1 June 1, 2006 12:09
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
