Normal shock in a ramjet intake. Backpressure imposing.
Like Tree2Likes
  • 1 Post By FMDenaro
Old   September 8, 2023, 07:00
Cool Normal shock in a ramjet intake. Backpressure imposing.
Miguel García
Miguelgh24 is on a distinguished road
Hi all,
I´m working in the design of a ramjet intake as my final thesis for my bachelor. The ramjet is going to work with mixed compression as it makes it more stable for different situations (Picture attached)
The problem that I´m facing is that I cannot get the normal shock formed. As you can see in the picture, the ramjet consists in a compression ramp, a constant section zone (isolator) and it ends with a divergent zone. I´m trying to get the normal shock wave in this last divergent section, so once the flow gets subsonic it can continue being decelerated ( working as a subsonic diffuser).
To get that normal shock in the divergent section, I must impose a backpressure at the outlet. As you can see in the picture attached, I´ve only used farfield pressure and outlet pressure boundaries. When I define pressure at the outlet, it is not considered when simulating, so the last section reaccelerate the flow (working as a supersonic nozzle).
I understand that in a supersonic flow, the outlet conditions have no influence upstream, but in this case, imposing backpressure is the only way to obtain the normal shock.
I´ve seen this same doubt in this and other forums, but I didn´t see any solution.These are the most relevant answers that I have seen:
1. In supersonic flow downstream properties are only defined by upstream flow. So imposing pressure at the outlet has no effect
Although it is not considered, the ramjet intake ends in a combustion chamber, so it must be a specific pressure in the outlet. It is also necessary to the normal shock formation.
2. Initialization importance. Once the freeflow simulation has converged, and the shock waves are established, impose the backpressure and simulate (without initializing)
I´ve tried this process and I get same results, it converge again, and shows the same as before.
3. Use pressure based solver and define the outlet as pressure outlet
I get same solution as using density based, so it has no effect. Furthermore, I thought density based solver is more suitable for supersonic simulations.
I haven´t seen seen any posts where the author gets the solution, however, I´ve seen different research articles with different ramjet geometries, achieving the normal shock with that back pressure imposing, so I know its possible. I´m new to CFD and Ansys Fluent (the software that I´m using), so maybe I´m making some other mistakes. Are the boundary conditions well suited?
I really appreciate all kind of help and discussion. It is my first post and I hope it is a good way of starting in this CFD world and forum.
Thank you,
Miguel
PD:
I´ve tried other geometries as a full external compression ramjet with constant section throat (picture attached), but neither could I get a neat normal shock.
Miguelgh24 is offline   Reply With Quote
Old   September 8, 2023, 09:39
Lucky
Use a pressure outlet.
What's your next question?
Old   September 8, 2023, 10:08
Miguel García
I am using pressure outlet, but changing the pressure has no effect and it is not considered. The outlet is determined by the upstream flow, so increasing pressure at the outlet has no effect. That's what I don't understand. I need that pressure to get the normal shock.
Old   September 8, 2023, 12:22
Joern Beilke
JBeilke is on a distinguished road
Your inlet on the left side should be defined as stagnation inlet.
JBeilke is offline   Reply With Quote
Old   September 8, 2023, 12:59
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Miguelgh24 View Post
Hi all,
I get same solution as before, so it has no effect.
Thank you,
Miguel
PD:
For such type of problem, I would use a density-based formulation. Clearly, for a supersonic outflow you have no effect in prescribing any Dirichlet BC, you must focus on the inlet condition. IF the inflow has fully supersonic conditions, you can prescribe the total enthalpy and the stagnation temperature T0. Then the velocity conditions and density.
The problem is different if you have subsonic inflow.
aerosayan likes this.
FMDenaro is offline   Reply With Quote
Old   September 8, 2023, 14:30
Miguel García
I´ve used it as velocity-inlet, and I get the same solution as pressure-farfield boundary. The outlet pressure is not considered, so there is no normal shock formed. Defining the inlet as pressure-inlet doesn´t make much sense, as the inlet velocity is known.
The inlet properties are:
Mach 3
Static Pressure 18800 Pa
Temperature 217K
Old   September 8, 2023, 14:40
Miguel García
Density based solver is used. The speed and altitude operation of the Ramjet are known, so I can define Temperature, Static Pressure, Mach number, Density.. at the inlet. However, what I can´t achieve is imposing pressure at the outlet. When I define the outlet as pressure outlet, the specified pressure is not considered.
The Ramjet operates at Mach 3, 18800 Pa and 217K (Pressure and Temperature defined by atmosphere altitude).
Old   September 8, 2023, 14:47
Density based solver is used. The speed and height operation of the Ramjet are known, so I can define Temperature, Static Pressure, Mach number, Density.. at the inlet. However, what I can´t achieve is imposing pressure at the outlet. When I define the outlet as pressure outlet, the specified pressure is not considered.
The Ramjet operates at Mach 3, 18800 Pa and 217K (Pressure and Temperature defined by atmosphere height).
You cannot prescribe pressure outlet (and any of the other variables) for supersonic outlet. What is the issue? This is what your flow problem requires.
Old   September 8, 2023, 15:00
Miguel García
Thats what I don´t understand. The only way to get a normal shock in a divergent section (which accelerates supersonic flow), is by imposing pressure at the outlet, otherwise the normal shock is not going to be formed.
I´ve seen different research articles that impose that backpressure, so they can get a normal shock in the duct.
I´ve also tried to get a normal shock in a constant section intake, but the shock wave reflections never end, and the normal shock is not formed.
Old   September 8, 2023, 15:08
But the presence of a normal shock in the divergent section will produce subsonic flows behind the shock and the outlet is, thus, subsonic. In such a case the pressure condition is well posed.
Miguelgh24 likes this.
Old   September 8, 2023, 15:14
Miguel García
Exactly, that´s what I´m trying to get. The normal shock will decelerate the flow to subsonic and pressure outlet boundary will be correctly defined.
It is not posible to get that normal shock without imposing pressure at the outlet. So its kind of a loop, I need the pressure to get the normal shock but I can´t define pressure outlet, until I get the normal shock.
At least, that´s what I understand.
Old   September 8, 2023, 16:47
Depending on the operating conditions at inflow, the shock can appear at the outlet section to satisfy the pressure condition.
Of course, the quasi one-dimensional theory is not exact for a two dimensional flow.
Old   September 8, 2023, 19:13
Joern Beilke
Mach 3
Temperature 217K
With this information known you can calculate the total pressure and total temperature and use a stagnation inlet.
Old   September 8, 2023, 21:56
Lucky
What is the issue? Do you have some miracle disease that puts you into cardiac arrest if you use a pressure outlet? Just do it.
A pressure outlet doesn't affect the characteristics of the upstream supersonic flow but that doesn't mean that it doesn't affect the flow. Consider what happens when you set the pressure outlet to be 10000 bar for example... And then consider what happens if you set the outlet pressure to 0 Pa. Imagine what happens... It will not always be ignored. You still must specify the correct static pressure condition since you expect the flow to eventually become subsonic after the normal shock.
If you don't get the flow you expect then either the value of the outlet pressure is wrong or your inlet BC is wrong.
Old   December 4, 2023, 01:30
Default Tried these ??
  #15
Adithya Ajay
Adithya Ajay is on a distinguished road
Hi all,
Thank you,
Miguel
PD:
1. Instead of farfield conditions, try Pressure inlet and at outlet pressure outlet
2. Experimentally how they impose the back pressure is by using a cone like structure at the exit to choke the flow . Cone can be moved along the aix left and right to control the pressure. You can make such a structure at the exit. I have seen some researchers simulating like this. This way you can avoid defining back pressure.
Adithya Ajay is offline   Reply With Quote
Old   December 21, 2023, 09:58
Saheb Bedi
sahebbedi is on a distinguished road
Are you using a steady state solver or transient sovler ?
Try using pseduo-time method under steady state and get an initial solution first with 1-3 bar and then amp the backpressure up.
sahebbedi is offline   Reply With Quote
compressible flow, ramjet, ramjet intake, supersonic, supersonic diffuser
Need help setting up chtMultiRegion OskarT OpenFOAM Pre-Processing 1 September 25, 2019 16:51
how can make normal shock in the nozzle at inlet B.C : Pressure Far field SonicGhoul FLUENT 2 May 8, 2016 06:16
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
Normal shock waves Fernando Velasco Main CFD Forum 1 April 6, 2000 15:10
