How to deal with the boundaries that the flow my enter or exit |
August 28, 2023, 05:36 |
Kevin
Rep Power: 4 |
Suppose we have a factory that has two big doors and a lot of windows at top of the walls. One door is on the north wall and the other door is on the west wall. Both doors are always open. As the wind flow direction is north to the south, we know that the flow enters from the north door. Also we assume that the windows are outlets which I think is a good assumption. But the problem is that we don't know that the flow enters from the west door (Inlet) or exits (Outlet). What should I do with the west door boundary condition? I use ANSYS FLUENT. Thanks. |
August 28, 2023, 09:11 |
Lucky
Rep Power: 66 |
You can use either a pressure inlet or outlet. The differences between them are:
Pressure inlet imposes stagnation conditions for inflows. Pressure outlet imposes static pressure at the boundary for outflow and static properties for inflow. You choose inlet or outlet based on the convenient of the properties you have at hand. You will get reverse flow warnings when an inlet has outflow and when an outlet has inflow, but they can be safely ignored. |
August 28, 2023, 09:43 |
Joern Beilke
Rep Power: 20 |
Place your boundaries outside of your building and also simulate the flow around the building.
August 29, 2023, 00:42 |
#4 | |
Kevin
Rep Power: 4 |
So, can I count on the reverse flow results? I mean where I get reverse flow warning, does it mean there is really a reverse flow and the reverse flow results are OK and accurate? Thank you. Thanks for your reply, but that makes the domain very wide and needs more computational resources. |
August 29, 2023, 03:34 |
Lucky
Rep Power: 66 |
You can do the test yourself with flow in a pipe. Use a pressure inlet at an outlet and watch what happens. Also use a pressure outlet at an inlet and watch what happens. Comment on the accuracy of the results. I give you homework.
boundary condition, fluent |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 18:22 |
How to set pressure boundary condition at the exit of a outer flow | HectorRedal | Main CFD Forum | 8 | June 29, 2022 06:00 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Flow rate at the exit of the vent | jai_helsing | FLUENT | 0 | October 31, 2018 12:04 |
mass flow inlet | Denis Tschumperle | FLUENT | 7 | August 9, 2000 03:19 |
