AMR settings (Transition Width, Face Validity, etc..) |
Kevin
Rep Power: 3 ![]() |
Currently using AMR for a simulation for a project I have been working on. I noticed I could change the value of "Transition Width" within the AMR settings. I read a little bit on it on the STAR-CCM's website, but still don't understand what it does. Can someone help me? Also, when using AMR, should I always enable the "check face validity" option? Why or why not? I added a screenshot of the settings for reference! Thanks! |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
There is a beautiful picture in the documentation that demonstrates quite clearly what transition width does.
Check face validity will enforce the face validity value in the next line. IYKYK. If you do check it, it does an extra sweep to force the face validity and takes longer to mesh. The benefit of doing this is... nothing if you have no clue what it does. I don't recommend to check every checkable box in Star. There is no achievement you can unlock in your profile for doing so. Finally, I don't even recommend using use AMR in the first place. Just learn how to mesh. |
amr, star ccm |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 18:25 |
su2 transition point and output settings | varghese9 | SU2 | 2 | March 5, 2015 12:13 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
