Inlet velocity profile for turbulent channel flow
Like Tree5Likes
  • 1 Post By LuckyTran
  • 2 Post By sbaffini
  • 1 Post By FMDenaro
Old   July 18, 2023, 09:04
Default Inlet velocity profile for turbulent channel flow
user2296 is on a distinguished road
for laminar flows in a channel flow, there are formulas for the inlet velocity which show a parabolic profile. Are there also formulas for the inlet velocity for a turbulent channel flow such that the velocity is zero at top and bottom walls?
Thanks
user2296 is offline   Reply With Quote
Old   July 18, 2023, 09:11
Lucky
There are approximate formula, not exact ones. The most popular is the 1/7-th power law profile.
If this accuracy is not enough for your needs, then simulate it yourself and map the profile over.
user2296 likes this.
Old   July 18, 2023, 12:26
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
There is no closed exact formula but, an addtional crude approximation is to use the wall distance as y value in any wall function formula (Musker, Reichardt, Spalding, Mixed Linear-Standard) and assigning a Cf, tau_Wall or Re_tau (from which u_tau can be derived, given the remaining case/fluid parameters).
If you really don't like the cusp at the channel center (altough, for very high Re, it is quite ininfluent), you can maybe use a pressure gradient sensitized wall function, one that gives you du/dy=0 at the channel half height. Or maybe use a composite function with some part for the outer layer.
FMDenaro and user2296 like this.
sbaffini is offline   Reply With Quote
Old   July 18, 2023, 12:48
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Just to add that all previous answers are correct and valid if you use the RANS formulation. For LES/DNS the generation of the inflow profile is a different matter.
FMDenaro is offline   Reply With Quote
Old   July 20, 2023, 06:26
@LuckyTran:
Thank you. Do u mean by 'map over' that I perform a first simulation with the 1/7 law as my inlet velocity profile and then take the resulting velocity values (e.g. from the outlet) and put them to the inlet for the second simulation?
Old   July 20, 2023, 09:44
Lucky
Yes you run a case that somehow gets you the velocity profile that you need. It can be 1/7, it can be uniform inlet. If you want the fully developed profile then I recommend to use a periodic BC in the streamwise direction. Then you take the now correct turbulent velocity profile and map it to the inlet to your case. But this is what you would do if you had a channel as part of a more complex geometry. You have a channel...
Can you not just extend the inlet upstream or just use the periodic BC if you want a fully developed profile?
Old   July 23, 2023, 05:37
Thanks again for your answer. I think that should work, I will try to use periodic BC and extend the inlet upstream, thank you.
cfd, channel flows
Ncrit for a glider Xfoil. How to use it. GPT4 answer AlanMattanó Main CFD Forum 0 April 10, 2023 13:16
How do I prescribe Average Velocity /Total Inlet Flow for a simple channel problem? skuznet OpenFOAM Pre-Processing 4 February 16, 2022 10:44
Is it possible the velocity profile changes in the fully-developed turbulent flow? czx0415 FLUENT 2 July 11, 2020 05:28
Velocity Profile at inlet if Mass flow rate BC is given Struggle_Achieve OpenFOAM Running, Solving & CFD 3 April 14, 2019 22:03
LES/RANS on Channel Flow Velocity Profile hx293 Main CFD Forum 15 August 29, 2017 12:34
