What is a Large Eddy Simulation without turbulent inflow?
Like Tree1Likes
  • 1 Post By FMDenaro
Old   June 20, 2023, 13:17
Default What is a Large Eddy Simulation without turbulent inflow?
ishan
ishan_ae is on a distinguished road
If inflow turbulence is not generated for a LES setup, will the LES solver act as an inviscid compressible flow solver ? Or is this behaviour code dependent ?
I think the behaviour will be like an inviscid compressible solver however, I would like to know why it would be or would not be.
ishan_ae is offline   Reply With Quote
Old   June 20, 2023, 14:27
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
No, not at all!
Your LES solution will develop a physically correlated turbulence after some lenght from the inflow section. But that depends also on the initial condition, if perturbed or not. If not, you can wait a lot of time unit before to see turbulence developed in a certain region of the computational domain.
Do not forget that a correct LES formulation is capable to solve the laminar, transitional and turbulent regime along a flat plate. Therefore, a laminar inflow is congruent, too.
ishan_ae likes this.
FMDenaro is online now   Reply With Quote
Old   June 20, 2023, 14:33
ishan
Thanks a lot.
large eddy simulations
Eddy diffusivity and the simple gradient diffusion hypothesis blyatman Main CFD Forum 4 September 16, 2021 21:52
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
Large Eddy Simulation with too high Mach number Roland R CFX 4 November 25, 2010 17:43
Large Eddy Simulation,,,???? tumble Hardware 3 February 16, 2010 18:36
Large Eddy simulation Andreas Hauser Main CFD Forum 1 May 20, 2000 21:33
