OpenFOAM: adjustTimeStep for shallowWaterFoam
Like Tree1Likes
  • 1 Post By LuckyTran
Old   June 9, 2023, 15:15
Default OpenFOAM: adjustTimeStep for shallowWaterFoam
Simone81 is on a distinguished road
I am running the shallowWaterFoam. I would like to have and adjustable time step based on the Courant number, see my controlDict below. My problem is that adjustTimeStep doesn't work. it seems the solver is indifferent to my controlDict setup. Any idea?
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  10
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    object      controlDict;
application     shallowWaterFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         40000;
deltaT          0.5;
writeControl    runTime;
writeInterval   1;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  on;
maxCo           1;
Simone81 is offline   Reply With Quote
Old   June 9, 2023, 18:45
Lucky
Indeed many of the basic solvers do not come with variable time stepping enabled. However, many of then can be made compatible by building your own solver. Please see this particular post for an example. In your case, create your own modified version of shallowWaterFoam by editing shallowWaterFoam.c (a good practice is to name it something else like myShallowWaterFoam). After updating the source code, build it by typing into a terminal
wmake myShallowWaterFoam
and then you can run your case by running
myShallowWaterFoam
Simone81 likes this.
Old   June 12, 2023, 15:44
This seems very helpful, thank you!
adjusttimestep, openfoam 10
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
How to develop OpenFOAM with CMake and popular IDEs cosscholar OpenFOAM Programming & Development 0 March 16, 2022 16:17
Solvers in OpenFOAM for LES + heat transfer arun1994 Main CFD Forum 1 November 26, 2021 08:57
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 1 November 7, 2015 16:16
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
