June 8, 2023, 09:00 |
Possible research areas in FSI
Amirhossein Taran
Rep Power: 10 |
Hi, everyone
I'm about to start research in the FSI (Fluid-solid-interaction) field. So far, I've worked mostly on multiphase flow, particle-laden flows, and LES. If you have any advice that could boost my literature review and help me find new and trending areas, I would really appreciate it. By the way, I would like to focus on the numerical and methodological aspects of FSI. Thanks. |
June 8, 2023, 23:03 |
Victor
Hi Amirhossein!
I'm currently working with DNS and Modal Stability analysis for aeroelastic systems, and nowadays I'm seeing a lot of effort in wind turbines DNS simulations accounting for Galloping, Flutter, and VIV of the base, and there's certainly a lot of room for research. There's a lot of room in Low order modelling as well, and the use of these concepts in FSI is really new. Hope I could insight you somehow. Cheers. |
June 13, 2023, 11:15 |
Amirhossein Taran
Rep Power: 10 |
Thanks Victor for your reply, I will check them.
Bests, Amirhossein. |
June 29, 2023, 06:51 |
Problem in two way FSI System Coupling
Piyush Zaware
Rep Power: 3 |
| The variable locations of force and heatflow variables for all Fluent |
| participants are set to 'Element'. Make sure that this is consistent with | | the setup within Fluent. When importing the SCI file (this includes running | | inside Workbench), you can control the locations of these variables by | | using the 'SYC_FLUENT_CONSNODAL' environment variable. For more | | information, refer to System Coupling User's Guide. |
fsi, research |
[solids4Foam] FSI case does not converge, foam extend 4.0 | MFWilliams | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 12 | May 13, 2022 09:35 |
Research areas for Master's course involving CFD applications | amolgole73 | FLUENT | 0 | June 10, 2020 09:14 |
Enhanced Multi-Physics Interface Research Engine (EMPIRE) for OpenFOAM FSI | danny261083 | OpenFOAM Programming & Development | 2 | May 3, 2016 14:01 |
Shallow water: research areas | phy4me | Main CFD Forum | 5 | December 5, 2011 10:09 |
Research areas in Fluid Dynamics/CFD with potentially significant commercial payoffs? | RossFS | Main CFD Forum | 1 | March 6, 2010 14:34 |
