OpenFOAM: read time-very inlet velocity from input file |
May 26, 2023, 17:29 |
Rep Power: 9 |
I need to read a time-very inlet velocity from input file, but apparently the option Code:
type csvFile; Code:
inlet { type uniformFixedValue; uniformValue { type tableFile; file "inputFile.txt"; } } Code:
( ( 0.1 0) (100 10.0) ) Code:
-> FOAM FATAL IO ERROR: Expected a '(' while reading VectorSpace<Form, Cmpt, Ncmpts>, found on line 28 the label 0 file: /home/foamCase/0/hU/boundaryField/inlet/uniformValue at line 28. From function Foam::Istream& Foam::Istream::readBegin(const char*) in file db/IOstreams/IOstreams/Istream.C at line 92. FOAM exiting Thank you! |
May 26, 2023, 18:38 |
Lucky
Rep Power: 66 |
uniformValue values are in () not {}
The hint was Code:
Expected a ( on line 28 +1 to the counter of OpenFOAM error messages actually indicating what is the error |
May 30, 2023, 17:43 |
Adam
The error suggests that there's an issue with the syntax or formatting of your file or boundary condition definition.
In your inputFile.txt, the correct format should be time first and then the value (velocity magnitude in this case) for each line. However, it also should be a list with the outer brackets.
Etsy to WooCommerce |
openfoam 10, tablefile |
[openSmoke] LaminarSMOKE compilation error | mdhfiz | OpenFOAM Community Contributions | 8 | July 2, 2024 10:32 |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
Postprocess: sampleDict works but creates no output folder | shock77 | OpenFOAM Post-Processing | 14 | November 15, 2021 08:27 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
