Error in chtMultiRegionFoam
Like Tree2Likes
  • 1 Post By LuckyTran
Old   May 25, 2023, 10:34
Default Error in chtMultiRegionFoam
TGS
TGS
TGS is on a distinguished road
I have three regions in my OpenFoam simulation. My geometry contains a solid fin that was covered by air at room temperature. The air flow is required to go through the fin as well. The one side wall of a fin has a temperature of 400 K. This is simply an air-cooled fin scenario. To solve this problem, I'm using the chtMultiRegionFoam solver, and I've successfully done blockMesh, TopoSet, splitMultiRegions, and snappyHexMesh. However, while I am running the chtMultiRegionsFoam, there is an error generated, and the error looks like this: I am new to OpenFoam and please help me to solve this error.
Thanks.
TGS
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 10
\\/ M anipulation |
Build : 10-c4cf895ad8fa
Exec : chtMultiRegionFoam
Date : May 25 2023
Time : 12:20:26
Host : "AIE-OpenFOAM"
PID : 129243
I/O : uncollated
Case : /home/thamasha/OpenFOAM/thamasha-10/run/NewFinT
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create fluid mesh for region air for time = 0
Create solid mesh for region fin for time = 0
Create solid mesh for region heatedBoundary for time = 0
PIMPLE: Region air
PIMPLE: No convergence criteria found
PIMPLE: Region fin
PIMPLE: Region heatedBoundary
PIMPLE: Operating solver in steady-state mode with 1 outer corrector
PIMPLE: Operating solver in SIMPLE mode
*** Reading fluid mesh thermophysical properties for region air
Adding to thermoFluid
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState rhoConst;
specie specie;
energy sensibleEnthalpy;
Adding to rhoFluid
Adding to UFluid
Adding to phiFluid
Adding to gFluid
Adding to hRefFluid
Adding to pRefFluid
Adding to ghFluid
Adding to ghfFluid
Adding to turbulenceFluid
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Adding to thermophysicalTransport
Selecting thermophysical transport type laminar
Selecting default laminar thermophysical transport model unityLewisFourier
Adding to reactionFluid
Combustion model not active: combustionProperties not found
Selecting combustion model none
Adding to KFluid
Adding to dpdtFluid
Adding to fieldsFluid
Adding MRF
No MRF models present
Adding fvModelsFluid
Creating fvModels from "constant/fvModels"
Selecting finite volume model type interRegionHeatTransfer
Selecting heatTransferModel constant
Adding fvConstraintsFluid
--> FOAM Warning : Creating fvConstraints from "system/fvOptions"
Selecting finite volume constraint type limitTemperature
- selecting all cells
- selected 1057 cell(s) with volume 79275
*** Reading solid mesh thermophysical properties for region fin
Adding to thermoSolid
type heSolidThermo;
transport constIsoSolid;
thermo eConst;
specie specie;
energy sensibleInternalEnergy;
Adding to fvModelsSolid
--> FOAM Warning : Creating fvModels from "system/fvOptions" rather than constant/fvModels
Adding fvConstraintsSolid
- selected 62 cell(s) with volume 4650
*** Reading solid mesh thermophysical properties for region heatedBoundary
type heSolidThermo;
thermo eConst;
specie specie;
Creating fvConstraints from "system/fvConstraints"
Selecting finite volume constraint type fixedTemperatureConstraint
- selected 1 cell(s) with volume 75
Region: air Courant Number mean: 1.35289e-05 max: 5e-05
Region: fin Diffusion Number mean: 4.88372e-10 max: 3.65798e-09
--> FOAM Warning :
From function Type Foam::gAverage(const Foam::UList<T>&, Foam::label) [with Type = double; Foam::label = int]
in file /home/ubuntu/OpenFOAM/OpenFOAM-10/src/OpenFOAM/lnInclude/FieldFunctions.C at line 597
empty field, returning zero.
Region: heatedBoundary Diffusion Number mean: 0 max: 3.65798e-09
--> FOAM Warning :
From function virtual void Foam:robes::findElements(const Foam::fvMesh&)
in file probes/probes.C at line 117
Did not find location (-0.054 0.018 0.017) in any cell. Skipping location.
--> FOAM Warning :
Did not find location (-0.054 0.018 -0.017) in any cell. Skipping location.
--> FOAM Warning :
Did not find location (-0.054 0.018 0) in any cell. Skipping location.
--> FOAM Warning :
Did not find location (-0.07 0.018 0) in any cell. Skipping location.
fieldAverage volAvgFinT:
Starting averaging at time 0
fieldAverage volAvgAirT:
deltaT = 0.0001
--> FOAM Warning :
deltaT = 0.000119048
Time = 0.000119048s
Solving for solid region fin
GAMG: Solving for e, Initial residual = 0.465165, Final residual = 0.401726, No Iterations 1000
Min/max T:300 300
Solving for solid region heatedBoundary
- selecting inter region mapping
Creating mesh-to-mesh addressing for heatedBoundary and air regions using cellVolumeWeight
Overlap volume: 0
diagonal: Solving for e, Initial residual = 0, Final residual = 0, No Iterations 0
Min/max T:300 399.987
Solving for fluid region air
DILUPBiCGStab: Solving for Ux, Initial residual = 0.998985, Final residual = 0.00181951, No Iterations 1
DILUPBiCGStab: Solving for Uy, Initial residual = 0.997048, Final residual = 0.00222112, No Iterations 1
DILUPBiCGStab: Solving for Uz, Initial residual = 1, Final residual = 0.00429678, No Iterations 1
--> FOAM FATAL ERROR:
request for polyMesh region0 from objectRegistry NewFinT failed
available objects of type polyMesh are
3
air
fin
heatedBoundary
From function const Type& Foam:bjectRegistry::lookupObject(const Foam::word&) const [with Type = Foam:olyMesh]
in file /home/ubuntu/OpenFOAM/OpenFOAM-10/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 211.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam:olyMesh const& Foam:bjectRegistry::lookupObject<Foam:olyMesh> (Foam::word const&) const at ??:?
#3 Foam::compressible::turbulentTemperatureCoupledBaf fleMixedFvPatchScalarField::updateCoeffs() at ??:?
#4 Foam::mixedFvPatchField<double>::evaluate(Foam::UP stream::commsTypes) at ??:?
#5 Foam::mixedEnergyFvPatchScalarField::updateCoeffs( ) at ??:?
#6 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
#7 Foam::tmp<Foam::fvMatrix<double> > Foam::fvModels::source<double, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&, Foam::dimensionSet const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
#8 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
#9 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
Aborted (core dumped)
TGS is offline   Reply With Quote
Old   May 25, 2023, 15:53
Lucky
You have 3 meshed regions named air, fin, and heated boundary. Your build is trying to find a meshed region that has the name "region0" and it doesn't exist.
Search all your dicts and find region0 and rename it to the correct region.
Since the solver stops right after completing one step through the air region but before printing the Courant number, the most likely culprit is probably in your controlDict in the CourantNo object. You most likely yoinked it from a tutorial and forgot to specify the region. Change region0 to air.
Co1
    // Mandatory entries (unmodifiable)
    type            CourantNo;
    libs            (fieldFunctionObjects);
    // Optional entries (runtime modifiable)
    rho             rho;
    // Optional (inherited) entries
    field           <phi>;
    result          <fieldResult>;
    region          region0;
    enabled         true;
    log             true;
    timeStart       0;
    timeEnd         1000;
    executeControl  timeStep;
    executeInterval 1;
    writeControl    timeStep;
    writeInterval   1;
TGS likes this.
Old   May 26, 2023, 04:50
TGS
TGS
Dear Lucky,
Thank you very much for the detailed answer and your time of helping me. I will try according to your advice and let you know.
Many thanks again.
TGS
Old   May 26, 2023, 05:56
TGS
TGS
Dear Lucky,
I tried by using the function that you mentioned in the thread to Courant number and changed the region to air. However, still I am getting the same error . Here I attached my controlDict file and the error message as well. If you have any free time ,can you please check it.
many thanks in advance.
TGS.
ControlDict file.
\\ / A nd | Version: 8
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application chtMultiRegionFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 10;
deltaT 0.0001;
writeControl adjustableRunTime;
writeInterval 0.01;
purgeWrite 0;
writeFormat binary;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable on;
adjustTimeStep on;
functions
probes
libs ("libsampling.so");
type probes;
// Name of the directory for probe data.
name probes;
// Write at same frequency as fields.
region air ;
enabled true;
log true;
timeStart 0;
timeEnd 10;
executeInterval 1;
writeInterval 1;
// Fields to be probed.
fields
p U T
probeLocations
( 26.25 18.75 1.25 ) // Exit from fin.
( 27.00 10.00 35.00 ) // Entrance to fin
( 28.50 20.00 40.00 ) // Above fin.
Co1
type CourantNo;
libs ("libfieldFunctionObjects.so");
region air;
enabled true;
log true;
timeStart 0;
timeEnd 10;
executeInterval 1;
writeInterval 1;
Error Message
\\/ M anipulation |
Date : May 26 2023
Time : 09:48:52
PID : 144895
I/O : uncollated
nProcs : 1
Create time
PIMPLE: Region air
PIMPLE: Region fin
type heRhoThermo;
transport const;
thermo hConst;
specie specie;
Adding to rhoFluid
Adding to UFluid
Adding to phiFluid
Adding to gFluid
Adding to hRefFluid
Adding to pRefFluid
Adding to ghFluid
Adding to ghfFluid
Adding to KFluid
Adding to dpdtFluid
Adding MRF
type heSolidThermo;
thermo eConst;
specie specie;
type heSolidThermo;
thermo eConst;
specie specie;
--> FOAM Warning :
deltaT = 0.0001
functionObjects::CourantNo Co1 writing field: Co
--> FOAM Warning :
Time = 0.000119048s
Min/max T:300 300
Overlap volume: 0
3
air
fin
heatedBoundary
FOAM aborting
Old   May 27, 2023, 02:33
Lucky
It still means that you have region region0 declared somewhere in one of your dicts. Ctrl + F is your friend
TGS likes this.
Old   May 31, 2023, 04:38
TGS
TGS
Dear Lucky,
Okay. I will search thank you so much.
TGS
chtmultiregion, openfaom, region0
chtMultiRegionFoam solver stops without any error amol_patel OpenFOAM Running, Solving & CFD 4 July 5, 2024 02:41
Help with PIMPLE algorithm in chtMultiregionFoam Chris T OpenFOAM Running, Solving & CFD 0 August 30, 2022 09:49
Error in thermophysical properties (chtMultiRegionFoam) mukut OpenFOAM Pre-Processing 28 November 23, 2021 07:34
Error in chtMultiRegionFoam kirankarki OpenFOAM 6 August 21, 2018 09:00
Simulation of a sample in a furnace w/ chtMultiRegionFoam sergimart7 OpenFOAM Running, Solving & CFD 7 August 12, 2015 07:48
