May 18, 2023, 06:32 |
Boundary condition determine
Super Coi
Rep Power: 3 |
Good day everyone, I'm a newbie in CFD - Fluent not sure how to determine the BC for my analysis. I have a small rectangle tank containing PCM, it just has 1 inlet to fill the PCM then it'll be capped. I need to simulate the heat transfer and thermal pressure of PCM to the tank in several temperatures but do not know how to set the BC (
I've already looked for some tutorials on youtube but they all have inlets and outlets and their shape are also different (normally is a cylinder). If someone can help, I'll be very appreciated. |
May 18, 2023, 07:16 |
Gert-Jan
Rep Power: 28 |
Better ask the fluent forum. There you have a larger audience.
Nevertheless, the simulations you found are mostly steady state, where fluid flows from inlet to outlet. You have an inherently transient process with 2 fluids. Initially a gas is present in which a fluids is poured. So setup a transient case with gas in the domain and let fluid enter the domain. Either as a function of time, or using a step function. This can be a massflow, or a uniform velocity, or a profile. That depends on what is in front of your inlet. Where does your gas go? Don't you need an outlet for this? Or is it just pressurized? |
May 18, 2023, 10:29 |
#3 | |
Super Coi
Rep Power: 3 |
Btw, thank you for your reply and also for mentioning the appearance of the gas which I didn’t notice. It can be another case for me to analyze this model. |
May 18, 2023, 10:35 |
Arjun
Rep Power: 34 |
Run the simulation as inlet bc first and then when want to switch change to outlet condition and continue
May 18, 2023, 10:43 |
Lucky
Rep Power: 66 |
You have PCM as well so it actually is 4 phases (a solid and liquid phase for the PCM). These problems can look deceptively simple because you encounter them everyday but end up being complex and computationally expensive when you want to take into account all the physics at the same time.
You can brute force and DNS your way through this case or you can model it further. Either way, it would vastly improve your understanding of the problem if you do some order of magnitude analysis and try to figure out what regimes you even have.
You my be able to reduce the complexity of the problem (from 4 phases down to 3 or 2 or maybe even 1) by coming up with these answers. |
May 18, 2023, 10:44 |
Super Coi
Rep Power: 3 |
Thank you for your suggestion, I’ll try it then
boundary condition, heat transfer boundary, pcm modeling |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Constant mass flow rate boundary condition | sahm | OpenFOAM | 0 | June 20, 2018 23:45 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
