Forces on aerodynamic tunnel in Space Vacuum
Like Tree1Likes
  • 1 Post By sbaffini
Old   May 10, 2023, 04:31
Default Forces on aerodynamic tunnel in Space Vacuum
Stoyan
StoyanNikolov is on a distinguished road
Hi is it Convenient to ask if
someone can say for sure about this topic
https://aviation.stackexchange.com/q...le/99002#99002
or to verify through simulation.
Please consider Option 1.
The only difference is that
the tunnel is in Space/Low Pressure/Vacuum.
https://i.stack.imgur.com/NUm5O.jpg
Thank you.
StoyanNikolov is offline   Reply With Quote
Old   May 10, 2023, 06:16
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
That's not how lift works, and you basically received on SE a number of answers that, collectively, contain most of the reasons for which it wouldn't work. The only way for an object to propel itself in a medium without direct interaction with it is by expelling mass.
Any other approach is basically "what you do to the surrounding medium, it does it backward to your system". None of the options you considered has an interaction with the surrounding medium known to produce what we call lift and, actually, option 1 will just fall.
Lift has nothing magic in it, and it is just the same force you experience when you put your hand out of the car window, but done better and at much higher speeds.
AtoHM likes this.
sbaffini is offline   Reply With Quote
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 19:05
Creating a vacuum space during initialization shuuyaan Fluent Multiphase 1 April 17, 2020 06:48
Run OpenFoam in 2 nodes of a cluster WhiteW OpenFOAM Running, Solving & CFD 16 December 20, 2016 01:51
[How to obtain supersonic flow inside a supersonic wind tunnel ?] yx213 Siemens 1 September 17, 2014 14:52
Vacuum in Space in Fluent hadi1984 FLUENT 0 February 2, 2010 01:15
