negative inlet temperature for axisymmetric nozzle flow using rhoCentralFoam
Like Tree1Likes
  • 1 Post By K-al-Eps-o
Old   May 3, 2023, 09:59
Lightbulb negative inlet temperature for axisymmetric nozzle flow using rhoCentralFoam
Baptiste
K-al-Eps-o is on a distinguished road
I have been trying to simulate a very simple nozzle flow with OpenFOAM flow in the past weeks. I have tried many different parameters and hypotheses, changing them only one at a time, but everyone one them has led to the same result: the simulation crashes with the error message "negative temperature inlet T0=-XXXK".
The domain I am considering is a short straight section followed by a simple convergent-divergent with straight walls sections. To take advantage of the geometry, I am solving the flow with axisymmetric BC. My domain is then a simple wedge - of less than 5°.
The domain is meshed with gmsh, creating a structured hexahedral mesh with grading from the center to the walls (growth ratio < 0.95). A grading is also applied from the inlet to the throat; after the throat, the mesh size is constant.
rhoCentralFoam is used as a density-based solver and different turbulent models have been tried - k-eps, RNG k-eps, k-omega-SST. The courant number is set to Co<0.2.
Boundary conditions are set as follow:
  • inlet:
    p: total pressure 9.1MPa
    U: InletOutlet
    T: total temperature 305K
    eps: zeroGradient
    omega: zeroGradient
    k: zeroGradient
    alphaT: calculated
  • outlet:
    p: wave transmissive 0.101MPa
    U: InletOutlet
    T: zeroGradient
    eps: zeroGradient
    omega: zeroGradient
    k: zeroGradient
    alphaT: calculated
  • walls:
    p: zeroGradient
    U: noSlip
    T: zeroGradient
    eps: epsilonWallFunction
    omega: kqRWallFunction
    k: kqRWallFunction
    alphaT: compressible::alphatWallFunction
  • wedges(lateral faces of the wedge):
    wedge
I am using CO2 in supercritical conditions as a fluid. I want to use a perfect gas model in the first place. Thus, my thermophysical properties as are follow:
thermoType
    type            hePsiThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
mixture
    // normalised gas
    specie
	nMoles		1;
        molWeight       44.01;
    thermodynamics
        Cp              2327;
        Hf              0;
    transport
	mu		1.444e-5;
	Pr		1.5;
For controlDisct, writeFormat is set to binary and writePrecision to 10 because I had issues with the wedge normals being misaligned; maxCo is set to 0.2 and maxDeltaT to 0.0001.
My fvSchemes is set as follow:
fluxScheme          Kurganov;
ddtSchemes
    default             Euler;
gradSchemes
    default             Gauss linear;
    limited             cellLimited Gauss linear 1;
divSchemes
    default             none;
    div(phi,U)          Gauss linearUpwind limited;
    div(phi,e)          Gauss linearUpwind limited;
    div(phi,K)          Gauss linearUpwind limited;
    turbulence          Gauss linearUpwind limited;
    div(phi,epsilon)    $turbulence;
    div(phi,k)          $turbulence;
        div(phi,omega)    $turbulence;
    div(phiv,p)         Gauss linearUpwind limited;
    div(((rho*nuEff)*dev2(T(grad(U)))))      Gauss linear;
    div(tauMC)      Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
    reconstruct(rho) vanLeer;
    reconstruct(U)  vanLeerV;
    reconstruct(T)  vanLeer;
snGradSchemes
    default         corrected;
wallDist
    method          meshWave;
and my fvSolution as follow:
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-08;
        relTol          0.01;
    pFinal
        $p;
        relTol          0;
    "rho.*"
        $p;
        tolerance       1e-05;
        relTol          0;
    "(omega|U|e|h|k|epsilon).*"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-08;
        relTol          0.01;
The problem is solved in parallel using mpi.
Parameters that I tried to modify:
  • play with the discretization schemes
  • change the initialization value of p and U
  • initialize k, eps, omega to high/low values to stabilize the solution
  • finner / coarser mesh
  • different geometries : change the throat and outlet diameters
  • turbulent models: k-eps, RNG k-eps, K-omega, K-omega-SST
  • change the turbulent quantities - k, eps, omega - at inlet (instead of zeroGradient BC)
  • zeroGradient BC for p at outlet
note: When solving in 2D - 3D mesh, 1 cell wide with empty BC - the simulation converges with k-omegaSST turbulence model. All the other models make the simulation diverge (same error).
I am open to any discussion about my simulation. Please don't hesitate to ask for more information.
Best.
K-al-Eps-o is offline   Reply With Quote
Old   May 3, 2023, 10:37
Baptiste
In addition, please find attached pictures of the mesh I am using.
I also want to mention that I tried tu implement limitTemperature with fvOptions. However, it led me to the same "negative inlet temperature" error.
Old   May 9, 2023, 05:08
Lightbulb rhoCentralFoam negative inlet temperature
Baptiste
By any chance, does anyone have any idea or insight ?
Best
Old   May 16, 2023, 12:14
Default Can someone answer to this post ?
Baptiste
Is there a way to get people to see this post ? I know that multiple post for the same probleme is not allowed.
Best.
Old   May 16, 2023, 12:18
K
kinematic_presser is on a distinguished road
OpenFOAM is not so good at importing meshes from other softwares. The negative temp at the inlet could be caused by misaligned normals. Check in gmsh that your normals are all pointing the correct direction.
kinematic_presser is offline   Reply With Quote
Old   May 16, 2023, 12:38
Baptiste
You think this issue could come from bad normals ? The fact that the simulation runs for a long time before it crashes doesn't exclude this hypothesis ?
Old   May 16, 2023, 13:55
Joern Beilke
JBeilke is on a distinguished road
Just have a look at this tutorial:
https://github.com/unicfdlab/hybridC...ivergingNozzle
It uses pimpleCentralFoam but might help.
JBeilke is offline   Reply With Quote
Old   June 8, 2023, 04:05
Default Solution
Baptiste
If anyone encounter a similar solution: I solved it by using setFields to initialize de fields in the domain.
The issue was that with the domain being initialized at 1bar and the inlet being at 91bar, it creates a shock in the convergent right at the beginning of the simulation. This shock propagates but unfortunately cannot be damped and creates a divergence when reaching the throat. By simply initializing the domain to highest pressures, and with a jump of pressure AFTER the throat, the simulation converged.
hogsonik likes this.
Old   June 8, 2023, 11:35
Lucky
I want to go back to something
You can imagine it is very hard for anyone to suggest a recommendation when it is already on the list of exclusions. It's like asking for recommendations to lose weight but "I've already tried changing my diet and exercising more and it didn't work." Well gee, I guess I forgot to mention that you need to decrease calorie intake and increase calorie consumption and every recommendation suddenly starts sounding like "just gitgud :4head:"
However, I do applaud you for updating your own post and confirming that initialization errors are still a common occurrence in 2023 and will likely continue to be a pain point for CFDers for the foreseeable future.
Old   June 13, 2023, 11:22
Baptiste
I can feel the sarcasm...
convergence, openfoam2212, rhocentralfoam
SU2 incompressible laminar flow mkulcsar SU2 3 April 30, 2023 23:59
Total pressure and mass flow boundary condition at inlet bscphil OpenFOAM Pre-Processing 3 July 9, 2017 15:39
Mass flow inlet with given temperature taalf SU2 3 October 15, 2015 15:25
Turbulent Intesity Inlet and outlet cavitating flow in Nozzle SPH_CFD FLUENT 2 April 29, 2015 09:51
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
