Is high aspect ratio a problem when the analysis is converged? |
Rep Power: 3 ![]() |
I want to know, if a mesh structure has high aspect ratio (about 1800) but the analysis is converged, is high aspect ratio a problem? Will my results inaccurate? Thank you! |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Yes high aspect ratio cells can still cause problems beyond convergence. Convergence is not a guarantee of accuracy.
But 1800...? Just delete the cell at that point. =) |
Thank you for replying.
The cells with high aspect ratio are inside the boundary layer. I don't think it's ok to delete them. And I cannot decrease it without increasing number of cells. |
aspect ratio, mesh |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
[ANSYS Meshing] High aspect ratio | Roby_1986 | ANSYS Meshing & Geometry | 0 | February 22, 2013 05:34 |
High aspect ratio problem.... | smjl | Main CFD Forum | 1 | October 23, 2011 05:48 |
pressure eq. "converges" after few time steps | maddalena | OpenFOAM Running, Solving & CFD | 69 | July 21, 2011 07:42 |
Problem on high density ratio in Level Set method | Kai Yan | Main CFD Forum | 10 | December 25, 2007 06:12 |
