Tool for Boundary Layer Meshing Setup
Like Tree2Likes
  • 2 Post By rollmops94
Old   April 2, 2023, 05:21
Lightbulb Tool for Boundary Layer Meshing Setup
Jonas
rollmops94 is on a distinguished road
Hi all,
I thought it might be helpful for some of you if I share the tool I developed to set up the meshing parameters for boundary layer meshing (prism layers/ inflation layers).
My main focus lies on external aerodynamic simulations of Formula Student and Formula One racecars and I struggled in the last years to find the right settings for the boundary layer mesh straight away.
Based on the equations and theory of flat plate, zero pressure gradient flat plate boundary layers, I developed the tool to visualize the mesh and relevant flow parameters.
The tool was so far only tested by myself, so please let me know if there is anything that needs improving or that does not seem correct.
The tool also contains a y+ calculator which feeds directly in the meshing settings.
For now, the tool is mainly designed for Reynolds Numbers between 1e4 and 1e6 but can also be used carefully for other Re numbers close to that range.
Some impressions:
I used Python3.9 with pyqt5 package for the software.
An installation is not needed, just download the zip file from here, unpack, and run the .exe:
https://dl.orangedox.com/Xas9Vy8FfboMmow0sW
This is definitely not malware, you can allow windows to run it.
Hope it helps and looking forward to getting some feedback,
Jonas
AtoHM and lvl99 like this.
rollmops94 is offline   Reply With Quote
boundary layer, inflation layer, meshing, preprocessing, prism layer
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[snappyHexMesh] Meshing connections of round and straight edges JShnyder OpenFOAM Meshing & Mesh Conversion 0 April 24, 2016 12:25
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 01:35
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
