March 18, 2023, 19:02 |
Particles with CD lower than a sphere
Marco D'Ario
Rep Power: 3 |
Hi, I have been doing CFDs for some months now using SU2 and INC_RANS, for incompressible fluid and symmetric particles (concave spheres generated by adding many cones on the surface of the sphere, see attachment for example). I am interested in the CD of those particles against the one for spheres of the same Re.
With my settings, I can perfectly recapitulate the CD of a sphere, with a 2% error. I recently discovered how to normalize the CD that SU2 returns, but for some of those particles (particularly those with many spikes), I get a lower CD than one of the spheres for Re<100. The CD can be as low as 20% lower than the one of a Sphere. From what I understand, this is impossible, as only asymmetric objects would have a lower CD when facing the flow towards the lower area of impact. Did anyone have a similar problem before, or think that those results are correct or can suggest what I might be doing wrong? I have been on this 24/7 for the past weeks and I checked every line of my code multiple times and I am 99% sure that what I am missing is not in my code. Again, my sphere behaviour is pristine. Thanks so much. |
cd estimate, su2 |
UDF in case with DPM modle | POSTHU | Fluent UDF and Scheme Programming | 0 | March 3, 2021 07:21 |
UDF for assigning particles position (re-injecting to the inlet) | cicatrix | Fluent UDF and Scheme Programming | 0 | November 11, 2019 07:11 |
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. | Ari | Fluent UDF and Scheme Programming | 4 | May 31, 2016 08:51 |
dsmcFoam - micro-hole limiting the number of dsmc particles | Araist | OpenFOAM Running, Solving & CFD | 0 | June 25, 2015 06:50 |
Straight through cyclone with particles | rogerhoffmann | CFX | 1 | May 21, 2012 18:42 |
