How can I find dimension of STL file?
Like Tree1Likes
  • 1 Post By sbaffini
Old   February 6, 2023, 06:56
Default How can I find dimension of STL file?
Song Young Ik
songyi719 is on a distinguished road
Hi, I am trying to do some car aerodynamic sim using openfoam, but problem is that stl file of car isn't aligned to be on ground.
Which means, xyz origin of file is somewhere inside the car.
But in order to stick this car on ground (well, cars don't fly) I should place wheel of this car on xy plane, or at least find out z value of wheel surface.
How would I be able to find out such data from stl file?
songyi719 is offline   Reply With Quote
Old   February 6, 2023, 07:01
Arjun
arjun will become famous soon enougharjun will become famous soon enough
There are lots of examples of stl file loaders on net if i am not mistaken. I would just read the stl myself and calculate the center by some C++ or C code.
arjun is offline   Reply With Quote
Old   February 6, 2023, 07:11
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
You should be able to import the STL in Paraview or Meshlab, find out the bounding box of the STL, notice the zmin of the bounding box and finally translate the STL along z so that z_translation = - zmin.
arjun likes this.
sbaffini is offline   Reply With Quote
Old   February 6, 2023, 16:56
sbaffini's Avatar
Paolo Lampitella
Note, however, that this is just the formal answer to your question. This is probably going to give you troubles somewhere along the road, besides being unphysical. It is common instead to have some compenetration between wheels and ground that is more close to the physical reality and better for meshing purposes.
stl
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
