Good estimates for the friction velocity? |
K
Rep Power: 3 ![]() |
Hello guys,
I am making a mesh for an airofoil and I need to figure out how close to the wall I am going to put the first grid point for suitability for LES. Of course the usual recommendation is to use a y+ of about 1, but I don't know how to translate a y+ of 1 into physical (y) units. We model the scenario with a flat plate of length ![]() ![]() ![]() We know, ![]() Where ![]() Is the friction velocity. So in order to estimate the value of y that corresponds to y+=1 , I need to have a good estimate for the friction velocity. I searched online but the only thing I found was this video (https://www.youtube.com/watch?v=SpkYBNdSOhQ) at 8:27, but he gives no reference. Anybody know a good source? |
#2 | |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
As you wrote, the friction velocity will be a result of the solution, thus you have to solve, compute, evaluate your y+ and if it is large refine the grid and solve again. In a channel flow you can see an expression based on the pressure gradient but that is not exactly your case. However, you can consider that for channel flows the bulk velocity-based Re number is O(10) times the Re_tau. |
K
But surely some decent estimate must be already known? My scenario is the standard flat-plate setup for boundary layer theory. How was the expression in the linked video obtained?
EDIT: Yes, known estimates exist. Scroll down here: https://www.cadence.com/ko_KR/home/t...cs/y-plus.html |
K
To answer my own question: A good estimate is known. Based on Fluid Mechanics by Frank M White,
![]() Which is obtained by combining the approximate expression (ignoring turbulent fluctuations) for the wall shear stress " ![]() ![]() |
The scaling (1/7) is from the polynomial assumption of the mean steady velocity. In the viscous sub-layer you have u+=y+ -> du+/dy+=1 then you can estimate du/dy|wall |
K
How can we estimate du/dy from du+/dy+ without knowing u* ?
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Either you do a crude CFD simulation first and get an estimate or the wall shear stress (and might as well get y+ from it while you're there) or you get your favorite empirical correlation for the wall shear stress from your favorite fluids handbook.
We often define friction velocity as the square root of the wall shear stress (divided by density of course) so there is no ambiguity and not using this du/dy stuff, they are the same of course if you hand-wave the notation. Note that when you are doing an order-of-magnitude estimate for the friction velocity, a reference is hardly ever given because you should just report the actual mesh size or wall y+ after you've done the CFD. |
K
#9 |
Lucky
Btw there is a Y+ calculator provided on the wiki, the links briefly lists over a dozen correlations for the friction coefficient, and gives some more references. So to the answer the original question, yes there are tons of available sources.
boundary layer, friction velocity |
Velocity Sampling in parallel simulation | Torii_Nagi | Fluent UDF and Scheme Programming | 1 | July 20, 2020 01:29 |
UDF srivastava and sundaresan friction model - divergence of the solutor | Luca_Panariello | Fluent Multiphase | 1 | January 18, 2017 10:07 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Friction velocity | Magnus123456 | FLUENT | 0 | March 3, 2014 10:50 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
