Reynolds number and Entrance length for flow between 2D parallel plates |
October 13, 2022, 09:58 |
Joshua Mathew
What is the formula to calculate the Reynolds number for parallel plates in 2D? If the distance between the plates is h, would it turn out to be Re = u x h / nu?
Would it be a case where a rectangular duct has no width and therefore the hydraulic diameter D = 4ab/2(a+b) would become D = 2a or 2h in this case? Does the length of the plates matter when calculating the Reynolds number or would it only affect the development or entrance length? |
October 13, 2022, 10:37 |
Lucky
Rep Power: 66 |
Parallel plates classically uses the gap height.
Yes the hydraulic diameter tends towards double the gap height and the two cases therefore have different Reynolds numbers definitions. Classically you study the fully developed flow between parallel plates and fully developed flow in pipes where the solution does not depend on streamwise location. There, the length of the plate doesn't matter. Length of the plate matters when it matters. If you have a developing bonundary layer then the length matters. You can calculate additional Reynolds numbers to characterize this. There's more than 1 Reynolds number. |
October 13, 2022, 11:31 |
#3 | |
Filippo Maria Denaro
Rep Power: 73 |
In such a case, just consider the theory of the boundary layer along one flat plate. It is the local Re number to be considered, at least until the two BLs will merge. |
entrance length, hydraulic diameter, parallel plates, reynolds number |
How to get the number of particles escaping from the entrance in DSMCFOam | bhwcs | OpenFOAM Pre-Processing | 0 | October 24, 2021 04:20 |
Reynolds number and time-dependent velocity | vavnoon | Main CFD Forum | 3 | July 10, 2020 11:15 |
Reynolds number | jeanpinto24| | OpenFOAM Pre-Processing | 6 | April 9, 2017 19:06 |
Relation to find out entrance length of MHD flow in rectangularchannel | mhdali101 | Main CFD Forum | 1 | July 1, 2015 03:37 |
entrance length | snowshovel | Main CFD Forum | 1 | April 15, 2008 08:46 |
