September 21, 2022, 07:38 |
Heat flux direction
Avon
Rep Power: 4 |
I'm quite confused on what my heat flux direction should be. I have a geometry like in the image attached in this email. The circle is generating 6W of heat. I defined the circle as solid & the rest as fluid. ANSYS says "A positive value of heat flux implies that heat enters into the domain"; so is this the direction of the red arrows or the green? Thank you |
September 21, 2022, 12:02 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
The normal unit to the boundary must be outward oriented. The vector heat flux in a fluid is q=-k*Grad T |
September 21, 2022, 13:30 |
Lucky
Rep Power: 66 |
If the black circular line is a wall then the red arrows is positive heat flux. Problem is you have an interface which means you'll have a wall and shadow-wall pair and you really should be careful because positive means along the surface normal of whichever is the wall and the wall could be facing either the fluid side or the solid side. A best practice is to put the wall facing the fluid side but it is entirely up to you and how you click buttons in Ansys which side is which.
September 23, 2022, 10:08 |
Avon
Rep Power: 4 |
I see, thank you!
September 23, 2022, 10:12 |
Avon
Rep Power: 4 |
That's very useful, thank you! I haven't used Fluent much so I wasn't aware of the shadowing at interfaces. Can I ask if you know what the wall thickness should be for a solid cylinder generating heat? I know you'd need to input the layer thickness for composite cylinders, but I'm not sure if, for a solid cylinder (i.e. the battery cells), I should type in the diameter or 0 for the wall thickness? Thanks! (I'm on about the wall thickness in the thermal tab btw)
September 23, 2022, 10:16 |
Lucky
Rep Power: 66 |
The wall thickness is for applying a shell conduction model. If you know, you know. If there is no shell conduction, then leave the thickness at 0.
September 23, 2022, 10:59 |
Avon
Rep Power: 4 |
Oh, I see. I'm not modelling two fluids separated by an interface - moreso a fluid flowing around solid cylinders, so I don't think I'm supposed to use a shell conduction model. Sorry last question lool: can I double check if I'm correct in thinking that if the wall thickness is 0, the heat generation rate (in W/m^3) should also be zero? I've made the heat flux non-zero though, by using Q"=Q/A, where A=2*pi*R*L (for the solid cylinders). It is a 2D simulation btw. Thank you so much!
Simulating constant heat flux value at solid-solid boundary | Y27 | STAR-CCM+ | 6 | September 8, 2020 10:56 |
Udf for moving heat flux in 2D cylindrical geometry | devia21 | Fluent UDF and Scheme Programming | 0 | April 20, 2015 01:27 |
Monitor Heat Flux in CFD-Pre | cltormar | CFX | 5 | November 20, 2014 12:45 |
Calculate heat flux direction | TrII4d | CFX | 4 | February 5, 2014 12:15 |
heat flux direction | uncle_salty | FLUENT | 1 | November 17, 2009 07:37 |
