Spectral method for two-phase flow
Like Tree1Likes
  • 1 Post By optimux
Old   September 7, 2022, 16:18
Default Spectral method for two-phase flow
optimux's Avatar
Mingming Zhang
optimux is on a distinguished road
Hi All,
I'm searching for spectral method used in a two-phase flow. Unfortunately, only a few papers that have something to do with this topic. Let's take the attached figure as an example: a box filled with hot liquid alloy, cooled from right and bottom walls while left and top walls are insulated. As it cools, liquid near right and bottom walls are going to crystallize, some crystals will attach to the walls while others will move along convection cells.
If boldly we assume all solid will attach to the walls, then this system can be described by the equations attached. The subscript L and S are liquid and solid. Darcy's law is also included for partially solidified region but we can neglect it here. The bar means time averaged value but for simplicity here we assume it's a constant. Latent heat denoted by Hs could be determined in physical space I guess.
So the problem is: is there a way to apply any kind of spectral method to this system? Most spectral method are working in a single phase. This problem is a two-phase flow and the solid region grows with time. All physical variables are multiplied by a solid or liquid fraction (fS or fL), I cannot get rid of them in a vorticity-streamfunction way.
Any ideas?
Best,
Mingming
File Type: jpg Screen Shot 2022-09-07 at 14.57.33.jpg (115.4 KB, 7 views)
aerosayan likes this.
optimux is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
How to calculate phase flow rate? sangramroy FLUENT 0 January 11, 2012 14:02
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 18:57
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM kenn Main CFD Forum 2 July 18, 2004 19:28
Solid-Liquid Two Phase Flow Numerical Simulation with the Finite Element Method Qing Hao Main CFD Forum 2 January 9, 1999 00:31
