Why does the non-orthogonal term in FVM need to be evaluated explicitly? |
Yu Wang
Rep Power: 4 ![]() |
In FVM, the face normal gradient is split into orthogonal and non-orthogonal part. The orthogonal part is evaluated implicitly, whereas the non-orthogonal part is evaluated explicitly as a source term using known velocity field. My question is why is the non-orthogonal part not implimented in a way such that it is evaluated implicitly? Is there any advantage in the explicit implimentation?
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
Could you better details your question with an example to a textbook/paper?
I suppose your are talking about FV on unatructured grids. |
#3 | |
Let's bypass the difficulty in tracking the coefficients with all the different methods and go straight to the point: you get an enlarged system band getting higher memory consumption, less cache efficiency and reduced diagonal dominance as you put in second layer neighbors. Deferred correction is just simpler and works better. |
Now let me highlight that tracking the coefficients for general methods is a real difficulty. For example, in my code I have a method where a weighted least squares gradient is used as initialization for a green gauss method. It's not impossible but nothing I want to deal with in a general purpose CFD code.
#5 | |
Sayan Bhattacharjee
Rep Power: 8 ![]() |
#6 | |
The issues are the book keeping to derive the exact coefficient formulas for each gradient method (and, as I wrote, some methods would be very challenging to derive, imagine debugging) and the matrix diagonal dominance in serial as well parallel. More off diagonal terms is bad for diagonal dominance independently from the parallelization. Even a single layer least squares gradient (which is super easy for the coefficients, because you already have them) still increases the number of layers by 1. |
fvm |
Named expression for volumetric heat source term that changes with time | Bran | FLUENT | 1 | August 12, 2020 21:57 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 05:58 |
FVM discretization of diffusion term on crvlnr gr | Michail | Main CFD Forum | 3 | March 14, 2008 06:52 |
Convective term evaluated at time n+1/2 | Lionel S. | Main CFD Forum | 0 | February 12, 2007 14:22 |
bouyancy term in epsilon equation | Michael | Main CFD Forum | 1 | June 25, 1999 10:20 |
