Is the Crank-Nicolson method for a parabolic pde with source term conditionally stabl
Like Tree4Likes
  • 1 Post By eozugurlu
  • 1 Post By FMDenaro
Old   September 2, 2022, 06:19
Default Is the Crank-Nicolson method for a parabolic pde with source term conditionally stabl
Ersin
eozugurlu is on a distinguished road
Dear All,
Is the Crank-Nicolson method for a parabolic pde with source term conditionally stable? Our source term is a typical rho*u*(1-u) where rho=0.023 (constant and small); our pde is u_t=a*u_xx+ rho*u*(1-u), u_x(x=0,t)=0, u_x(x=1,t)=0, u(0,t) is given as well.
When we try to show the stability of the Crank-Nicolson, first of all we take the linear form of the source term as rho*u.
We get the amplification factor as
g=(1-2*R sin^2(theta/2)+(1/2)*rho*Delta t)/(1+2*R sin^2(theta/2)-(1/2)*rho*Delta t)
where R=(a*Delta t)/(Delta x)^2.
To get |g|<=1 we get a conditional stability ???? Is this normal? Today, I have read an article "Stability analysis of Crank–Nicolson and Euler schemes
for time-dependent diffusion equations" by Cassio M. Oishi · Jin Y. Yuan ·
Jose A. Cuminato · David E. Stewart and they say that if the BC is explicit then the Crank-Nicolson is conditionally stable.
aerosayan likes this.
eozugurlu is offline   Reply With Quote
Old   September 2, 2022, 09:07
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by eozugurlu View Post
Dear All,
Before addressing my opinion, I would be sure of your scheme for the source term. It is explicit or implicit?
FMDenaro is offline   Reply With Quote
Old   September 2, 2022, 10:07
Default source term is treated as implicit ...
Ersin
source term is treated as rho*(u_m^n+1 + u_m^n)/2 in Crank-Nicolson.
Old   September 2, 2022, 10:28
Ok, assuming a convection-diffusion-production equation, you have to produce the stabilty regions like I computed here. If you disregard the convection you have one plane since G_max(alpha,rho) for any theta.
https://www.researchgate.net/publica...extFileContent
Old   September 2, 2022, 10:41
Ersin
you are not using Crank-Nicolson, your scheme is an explicit one.
Old   September 2, 2022, 11:57
Yes and what is the issue? For implicit scheme You have only to divide the RHS by the expression the multiplies E_n+1 in the LHS and you have G exactly like for explicit scheme.
Old   September 2, 2022, 13:42
This is what I found in your case
File Type: jpg 0C7D901B-4E34-4244-AAE9-12B8C07CDC26.jpg (39.0 KB, 8 views)
Old   September 2, 2022, 13:44
Ersin
Dear Dr. Denaro,
We get the amplification factor using the Crank-Nicolson method applied to
as
Can you say that the Crank-Nicolson method is unconditionally stable?
Old   September 2, 2022, 13:48
Dear Dr. Denaro,
as
You cannot do that. The classical von Neumann stability analsys applies for the linear case, you cannot use the analsys as-it-is for the non linear case.
Old   September 2, 2022, 13:52
Ersin
I have stated that I applied it to the linear form in my first post
Old   September 2, 2022, 13:54
Ersin
what can you say about the stability then? Is the ratio less than 1 for every Delta and Delta x?
Old   September 2, 2022, 14:02
Dear Dr. Denaro,
as
You wrote the non linear source term.
I wrote in my note the amplification factor for the linear source term, you can deduce the condition for G(alpha, beta) at the worst theta =k*h condition.
[openSmoke] LaminarSMOKE compilation error mdhfiz OpenFOAM Community Contributions 8 July 2, 2024 11:32
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
How to add Source term (2) for PYROLYSIS - reactingOneDim Kummi OpenFOAM 10 April 12, 2021 22:11
Source term for EVAPORATION in Energy Equ. - technical difficulty ? Kummi OpenFOAM 1 September 9, 2019 10:32
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
