Export to STP from SpaceClaim
Like Tree1Likes
  • 1 Post By Trupen
Old   July 15, 2022, 18:17
Exclamation Export to STP from SpaceClaim
Chiara
Chiara1618 is on a distinguished road
I'd like to export my geometry from SpaceClaim to .STP file type. Unfortunately From the drop down menu I only have the option to export it in .scdoc file type and I don't have all the other options as the Ansys Manual says or as all the tutorial show...
Any idea why does this happen and how to solve it?
Thank you
Chiara1618 is offline   Reply With Quote
Old   July 15, 2022, 19:50
sensitiveLook is on a distinguished road
Its possibly because your geometry isn't suitable for exporting i.e. it has some errors which make it invalid. If not so, if you could give more info on your geometry or how you're running spaceclaim, then I could suggest better.
sensitiveLook is offline   Reply With Quote
Old   July 17, 2022, 14:47
Chiara
The Geometry comes from an .stp file, so if I don't make any changes I should be able do export it from Space Claim again in .stp format...
I'm running on the student version, could it be the problem?
Old   July 17, 2022, 15:13
Yes possibly. That could be a cause. SpaceClaim has a limitation of max 50 bodies and max 300 faces once imported into Workbench. If your .stp file exceeds these, its possible you can't export.
Old   July 18, 2022, 04:47
Chiara
Then for sure that’s the cause!! Thank you very much����
Old   August 26, 2022, 16:19
Trupen
Trupen is on a distinguished road
Now spaceclaim student version only allows to export the geometry in spaceclaim format (.scdoc). Unlike previous limitations like 50 bodies and 300 faces doesn't matter now. Even if its just one body, you won't be able to export in step format unfortunately.
MTomić likes this.
Trupen is offline   Reply With Quote
ansys, scdoc, spaceclaim, step, stp
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 20:15
[foam-extend.org] foam-extend-4.0 gcc errors & maybe paraFoam powerline332 OpenFOAM Installation 3 May 24, 2018 22:16
A CFX-POST error (ver 14.5.7) wangyflp88 CFX 2 July 22, 2017 01:17
Unable to install OpenFOAM 1.6-ext Maimouna OpenFOAM Installation 23 May 8, 2014 06:47
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
