Can CFD help with seeing if flow becomes turbulent?
Like Tree2Likes
  • 1 Post By LuckyTran
  • 1 Post By FMDenaro
Old   July 6, 2022, 10:38
Default Can CFD help with seeing if flow becomes turbulent?
highhopes is on a distinguished road
Dear respected members of the CFD community,
Recently I attended a talk about computational investigation of a viscous flow in a conduit. The speaker said they had to switch to turbulence modeling because the flow "became" turbulent around a turn. I asked them how they came to the conclusion that there was a transition and they said it was a computational finding. I could not ask any further because of time constraints but I had to take the answer with a pinch of salt because the decision sounded a little too casual to me.
Here I would like to ask you if there is actually a way of deciding whether a laminar flow gets turbulent anywhere downstream? I would love to hear your thoughts on this.
Thank you.
highhopes is offline   Reply With Quote
Old   July 6, 2022, 10:47
Lucky
I highly doubt it was purely a computational finding. I'll believe that when I see it. If that work was performed, it'd be groundbreaking.
I will accept that they used some other practical judgement such as checking the duct Reynolds number and finding out that it was greater than 2300, or something of this level of simplicity.
Even DNS doesn't magically yield that a pipe flow is turbulent at Re=2350, we have to resort to stochastic methods to get this result.
highhopes likes this.
Old   July 6, 2022, 14:44
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Thank you.
Generally, what you are asking for is the capability of CFD in simulating a transitional flow, that is a condition in which laminar, transitional and turbulent regime coexist.
This kind of problem can be afforded only with a DNS formulation, LES with a wall resolved grid and a good SGS model could be also a good candidate.
FMDenaro is offline   Reply With Quote
Old   July 11, 2022, 09:52
Thank you very much for your answers. I had also figured this sort of simulation would be close to impossible considering the low computational resources.
Also thank you very much letting me know that, even expensive, there are ways to locate transition from laminar to turbulent flow via computations.
Drag Force Ratio for Flat Plate Rob Wilk Main CFD Forum 40 May 10, 2020 05:47
Will the results of steady state solver and transient solver be same? carye OpenFOAM Running, Solving & CFD 9 December 28, 2019 06:21
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? JuPa CFX 7 September 9, 2013 08:45
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
