Air flows from lower total pressure to higher total pressure
Like Tree1Likes
  • 1 Post By LuckyTran
Old   July 3, 2022, 00:50
Arrow Air flows from lower total pressure to higher total pressure
Kevin
kevinpwp is on a distinguished road
I'm simulating a natural exhaust hood.
The air near the hot surface has a lower density so it will go up due to buoyancy.
I have checked the outlet flow rate and it has an outlet volumetric flow rate of 1000 m3/hr without any reverse flow.
The problem is that the total pressure at the outlet is much higher than the duct entry. So, how the air can exit the outlet while the fluid flows from higher total pressure (TP) to lower pressure?
You can see the pressure contours below:
Thank you!
kevinpwp is offline   Reply With Quote
Old   July 3, 2022, 01:11
Lucky
You have an external force, gravity aka your buoyancy force!
Not sure if it's relevant but you should also be careful what is the definition of pressure, static pressure, and total pressure when working with gravity driven flows because it may or mot not include the hydrostatic component.
kevinpwp likes this.
Old   July 3, 2022, 01:29
Kevin
Thank you for your reply. I use ANSYS Fluent and I think the total pressure also includes the buoyancy force effect which results a pressure difference of "dP=g*h*(rho_1-rho_2)".
You mean I have to define a function as: FULL_PRESSURE= Total Pressure -rho*g*y?
I'm confused.
Old   July 3, 2022, 02:06
Lucky
There is a lot going on in this picture that is not easily explained away by a few words especially when you are confused what is pressure.
To make it even more confusing, there's also heat transfer and you're putting energy into the flow.
buoyancy driven flow, pressure and velocity
chtMultiRegionFoam speed up qwertz OpenFOAM Running, Solving & CFD 8 September 18, 2021 07:16
Getting divergence while increasing the back pressure at pressure outlet greenfields15 FLUENT 0 March 19, 2018 00:39
total pressure and pressure drop omaralyahia CFX 5 July 14, 2015 09:13
Dynamic pressure from the total pressure specified saisanthoshm88 CFX 1 August 9, 2012 07:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
