FIDAP - running it in 2022
Like Tree2Likes
  • 1 Post By JBeilke
  • 1 Post By Gerry Kan
Old   June 8, 2022, 15:12
Default FIDAP - running it in 2022
Doug
ntrop is on a distinguished road
I have many legacy models built in FIDAP. Unfortunately, the technique that I last used (2016) to run the software no longer correctly launches the GUI. Specifically, I am now running Windows 10 with Exceed and FIDAP launches and creates most of the correct GUI but not enough of it to fully utilize the GUI. I know the software is a bit of a dinosaur at this point, but the models involve free surface flows and these are not handled (at least to my satisfaction) in FLUENT. Anyone out there using FIDAP or had experience getting old software that needed X-terminal emulation to work in 2022? Much thanks.
ntrop is offline   Reply With Quote
Old   June 8, 2022, 17:45
Joern Beilke
JBeilke is on a distinguished road
You can install "VMWARE Workstation" on top of your Windows installation and run whatever guest operating system you want on it.
ntrop likes this.
JBeilke is offline   Reply With Quote
Old   June 8, 2022, 18:52
Gerry Kan's Avatar
Gerry Kan
Gerry Kan is on a distinguished road
If you are running Exceed, am I correct to assume that you are running FIDAP off some Unix box through your Windows machine? Can you by any chance run FIDAP without problems directly off the machine where it is installed?
I don't know how old your version of FIDAP is, but I think your problem might have to do with the X fonts or graphics (not widgets, with which the GUI components like windows and buttons are drawn). Your version of Exceed (assuming it's "old") might also be an issue, as in the past I have seen users having GUI display issues with much older versions of Exceed.
ntrop likes this.
Gerry Kan is offline   Reply With Quote
Old   June 9, 2022, 12:33
Doug
Thanks, Gerry and Joern for your quick replies. I passed your recommendations on to the IT person who is helping me to resolve this.
exceed, fidap
ANSYS Licensing Problem, Processes Running but Showing as Not Running penguinman ANSYS 3 September 27, 2016 14:30
Hypersonic Sim (running at Mach 7): floating point exception has occurred bungusbeefcake STAR-CCM+ 10 March 31, 2015 07:59
Fluent 14.0 file not running in parallel mode in cluster tejakalva FLUENT 0 February 4, 2015 08:02
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 05:59
Fidap to Fluent Ravi FLUENT 3 July 10, 2008 14:31
