Aeroacoustics of Quadcopters
Like Tree1Likes
  • 1 Post By erkampasha
Old   April 16, 2022, 07:59
Default Aeroacoustics of Quadcopters
Abdul Samad
Al_Psi is on a distinguished road
Hi.
I am trying to get acoustics signature of a quadcopter.
Can someone please guide me how to setup the model for a hovering platform. What should be the inlet and exit conditions, with no x and y velocity?
i am using Moving mesh for fluid domain against each rotor, do I need to employ moving wall for the blades inside the domain as well.
i was getting reverse flow at exit for pressure outlet, tried to replace it with outflow but the problem still persists?
Any suggestions please?
Regards
Al_Psi is offline   Reply With Quote
Old   April 26, 2022, 08:58
İbrahim
erkampasha is on a distinguished road
Originally Posted by Al_Psi View Post
Hi.
Regards
You do not need to give motion to blades. Do overset mesh which includes blades and give the motion to zone you ve created with overset. You can create circle domain which has 1 boundary. And apply pressure inlet boundary condition which has value of 0 pa under the atmosphere pressure. And you should create your domain bigger than you have create to get rid of reverse flow.
Al_Psi likes this.
erkampasha is offline   Reply With Quote
aeroacoustics, audio file, quadcopter
Aeroacoustics Simulation in Star CCM+ using FW-H Model ram2013aero STAR-CCM+ 0 January 21, 2022 12:54
OPENFOAM for Aeroacoustics simulations (using Linearized Euler Equations) ms518 OpenFOAM 6 February 21, 2021 17:49
What parameters can be used for processing aeroacoustics in a DES CFD simulation ? ishan_ae FLUENT 0 March 22, 2018 05:19
aeroacoustics Constantinos Main CFD Forum 1 March 22, 2004 14:32
Aeroacoustics - Flow over Cylinder Axel Rohde Main CFD Forum 2 August 17, 2002 13:18
