Implicit supseronic flow simulations in flexi
Like Tree6Likes
  • 1 Post By vachan
  • 1 Post By Eifoehn4
  • 1 Post By vachan
  • 1 Post By JonaZ
  • 1 Post By vachan
  • 1 Post By JonaZ
Old   March 30, 2022, 05:56
Default Implicit supseronic flow simulations in flexi
Vachan Potluri
vachan is on a distinguished road
Dear all,
I am trying to perform a Mach 2 supersonic flow simulation in flexi (https://www.flexi-project.org/) using implicit time stepping.
Flexi user guide describes how to do implicit simulation for a Mach 0.2 RANS flat plate simulation. However, I am unable to obtain the correct solution with implicit time stepping in the supersonic case I am interested in.
The simulation I am doing is of an impinging shock-boundary layer interaction. I am pasting my settings here and attaching the mesh file (degrez_corrected_mesh.h5) as a part of the zipped attachment to this post.
! OUTPUT
ProjectName = degrez_corrected
Logging = F
ErrorFiles = T
OutputFormat = 0
doPrintStatusLine = T
ColoredOutput = F
! Interpolation
N = 2
NVisu = 2
NOut = 2
! Mesh
MeshFile = degrez_corrected_mesh.h5
useCurveds = F
crossProductMetrics = F
! Equation
IniExactFunc = 1
IniRefState = 3
kappa = 1.400
R = 286.689
Pr = 0.69
mu0 = 1.716e-5
! mu0 = 0.0
Ts = 111
Tref = 273
RefState = (/1,0,0,0,1718.81/) ! gives outflow pressure
RefState = (/0.0290566,519.41,-34.6182,0,1393.6/) ! post shock conditions
RefState = (/0.0248218,540,0,0,1117.3/) ! pre shock conditions (freestream)
BoundaryName = back
BoundaryType = (/9,0/)
BoundaryName = front
BoundaryName = wall
BoundaryType = (/3,1/)
BoundaryName = outflow
BoundaryType = (/24,1/)
BoundaryName = post_shock_inflow
BoundaryType = (/2,2/)
BoundaryName = pre_shock_inflow
BoundaryType = (/2,3/)
! Riemann
Riemann = 33
RiemannBC = -1
! FV-Subcell
IndicatorType = Jameson
IndVar = 6
FV_LimiterType = 1
FV_IndUpperThreshold = 0.010 ! upper threshold (if IndValue above this value, switch to FV)
FV_IndLowerThreshold = 0.005 ! lower threshold (if IndValue below this value, switch to DG)
FV_toDG_indicator = T
FV_toDG_limit = -5.5
FV_IniSupersample = T
! TimeDisc
TimeDiscMethod = esdirk3-4
TEnd = 3e-3
CFLScale = 2.5
DFLScale = 2.5
! EpsNewton = 1e-2
adaptepsNewton = T
! nNewtonIter = 100
! FD_Order = 1
! EpsGMRES = 1e-1
! nRestarts = 50
! nKDim = 50
! PrecondType = 0
NoFillIn = T
SolveSystem = 1
! HyperbolicPrecond = T
! DoDisplayPrecond = T
! Analyze
Analyze_dt = 3e-6
nWriteData = 1
CalcResiduals = F
CalcErrorNorms = F
varName = Density
varName = Pressure
varName = VelocityX
varName = VelocityY
varName = Temperature
Even for a CFL value as small as 2.5, flexi reports the following:
Attention: Timestep failed, repeating with dt/2!
And then strangely, except for first few outputs, flexi reports zero GMRES and Newton iterations:
 Timestep   :    5.8680110E-07
#Timesteps  :    1.6000000E+01
#GMRES iter  :    0.0000000E+00
#Newton iter :    0.0000000E+00
I have also put the log file (flexi.log) generated with these specific settings in the zipped attachment. The result files show unphysical solution with negative pressure and extreme oscillations. I have also tried changing the preconditioner and tolerances. They seem to just delay/advance such behaviour, but I wasn't able to get a clean simulation.
My build settings:
CMAKE_BUILD_TYPE                 Release
 CMAKE_INSTALL_PREFIX             /home/vachan/Documents/Work/flexi-framework/flexi
 FLEXI_2D                         ON
 FLEXI_EDDYVISCOSITY              OFF
 FLEXI_EQNSYSNAME                 navierstokes
 FLEXI_FV                         ON
 FLEXI_FV_RECONSTRUCTION          ON
 FLEXI_LIFTING                    br2
 FLEXI_NODETYPE                   GAUSS-LOBATTO
 FLEXI_PARABOLIC                  ON
 FLEXI_PERFORMANCE                ON
 FLEXI_POLYNOMIAL_DEGREE          N
 FLEXI_SPLIT_DG                   ON
 FLEXI_TESTCASE                   default
 FLEXI_VISCOSITY                  sutherland
 LIBS_BUILD_HDF5                  ON
 LIBS_BUILD_MATH_LIB              OFF
 LIBS_USE_MKL                     OFF
 LIBS_USE_MPI                     ON
 LIBS_USE_OPENMP                  OFF
 LIBS_USE_PAPI                    OFF
 POSTI                            ON
 POSTI_AVG2D                      OFF
 POSTI_CHANNEL_FFT                OFF
 POSTI_DMD                        OFF
 POSTI_MERGETIMEAVERAGES          OFF
 POSTI_RP_EVALUATE                OFF
 POSTI_RP_PREPARE                 OFF
 POSTI_RP_VISUALIZE               OFF
 POSTI_SWAPMESH                   OFF
 POSTI_TO3D                       OFF
 POSTI_VISU                       ON
 POSTI_VISU_PARAVIEW              OFF
 POSTI_WALLDISTANCE               OFF
 USE_PGO                          ON
Am I missing some key setting, or do I have any setting wrong? Kindly help me in getting this simulation right.
Thanking in anticipation
Vachan
flexi-project likes this.
vachan is offline   Reply With Quote
Old   March 31, 2022, 16:16
Eifoehn4's Avatar
Eifoehn4 is on a distinguished road
Dear vachan,
I will contact my FLEXI collegues. We're going to make this work!
Regards
Check out my side project:
A multiphysics discontinuous Galerkin framework: Youtube, Gitlab.
Eifoehn4 is offline   Reply With Quote
Old   April 1, 2022, 01:24
Vachan Potluri
Thanks a lot, Eifoehn4! I am truly grateful for your quick response and support!
Old   April 1, 2022, 08:04
Jonas Z.
JonaZ is on a distinguished road
Dear Vachan,
there was indeed a bug in the code that caused this behavior you observed. We fixed this and the updated version will be available on github after the weekend. So just pull the most recent version on Monday and you can run your simulation!
What you observed was the following: the bug caused not choosing the shock-capturing scheme property. This then resulted in instabilities, so FLEXI tried to repeat the timestep but it was never stable.
Though, I am not sure if implicit time discretization is the best choice for your setting. As the Mach number is quite high and the solution (especially in the beginning) changes rapidly, the implicit method is not able to use very large timesteps. So you maybe have to ramp your timestep to obtain a stable simulation.
Kind regards,
Jonas
JonaZ is offline   Reply With Quote
Old   April 1, 2022, 08:15
Vachan Potluri
Dear Jonas,
Great! Thanks very much for such a prompt response.
I felt that the issue was due to some minor oversight. Glad it was debugged!
Will keep your suggestions in mind.
Thanks again for such a quick response!
Old   April 4, 2022, 02:30
Default Still not working?
Vachan Potluri
Dear Jonas,
As you said, I have noticed that a commit for the bug fix has been made to the github repo: https://github.com/flexi-framework/f...acaf6dd614ba21.
I have compiled the latest version of flexi now. However, I am afraid this still didn't improve the performance of implicit stepping.
This time, I started the implicit solution (with CFL 5 and the settings pasted below) with the solution at 1e-3 sec obtained through explicit stepping (standardrk3-3). By my estimate, the flow becomes steady in about 3e-3 sec. So at 1e-3 sec, most of the transients are gone, and it is only a matter of the separation region growing to its full size after this point.
! TimeDisc
TEnd = 3e-3
CFLScale = 5
DFLScale = 5
! EpsNewton = 1e-2
adaptepsNewton = T
nNewtonIter = 100
FD_Order = 1
EpsGMRES = 1e-1
nRestarts = 50
nKDim = 50
PrecondType = 1
NoFillIn = T
SolveSystem = 1
Even then, I still get this message:
So is it possible that there is something still left to be resolved? Or, please let me know if I am setting something incorrectly.
Thanking again,
Vachan
Old   April 6, 2022, 09:54
Jonas Z.
Dear Vachan,
I am not completely sure why this is happening in your case - there is something going wrong with the preconditioner. We probably will need some time to figure that out.
In the meanwile I would suggest to use either fully explicit methods or implicit methods without preconditioning and additionally change your settings slightly:
! TimeDisc
TEnd = 3e-3
CFLScale = 5
DFLScale = 5
EpsNewton = 1e-2
adaptepsNewton = F
nNewtonIter = 10
FD_Order = 1
EpsGMRES = 1e-1
nRestarts = 5
nKDim = 30
PrecondType = 0
I hope this helps you and we will continue working on making the use of a preconditioner for this setting to work.
Kind regards,
Jonas
Eifoehn4 likes this.
Old   April 7, 2022, 01:46
Vachan Potluri
Dear Jonas,
Thanks for your response. It is indeed running fine without the preconditioner and your suggestions.
I wish and hope that the issue in preconditioner will be sorted out soon!
Thanking again,
Vachan
Old   April 14, 2022, 06:28
Jonas Z.
Dear Vachan,
I had a closer look on your problem and I think the main issue that causes bad convergence behaviors is the non-linearity of the slope limiting procedure (you selected "minmod" limiting).
In this forum thread http://www.cfd-online.com/Forums/mai...d-limiter.html you find a related discussion and in the publications
W. Gropp, D. Keyes, L. C. McInnes, M. D. Tidriri: Globalized Newton-Krylow-Schwarz algorithms and software for parallel implicit CFD. The International Journal of High Performance Computing Applications 14(2), 102-136 (2000)
and
P. A.Burton, P. K. Sweby: A Dynamical Approach Study of Some Explicit and Implicit TVD Schemes and Their Convergences to Steady-state Solutions. Numerical Analysis Report 5/95, University of Reading, Department of Mathematics, 1995.
you find some investigations on this.
I therefore recommend you to use the first order finite volume scheme for shock capturing, i.e.
FV_LimiterType = 0
In a future release of FLEXI there might be the van Albada limiter. Even though, this limiter significantly improves the convergence properties compared to minmod limiting, it is still quite difficult to use very large timesteps.
Moreover, it is recommendable to change your preconditioner settings as I observed that the accuracy of the preconditioner with ILU(0) inversion of the blocks is not sufficient for larger timesteps for your setting. Maybe you can try the following settings:
PrecondType = 1
NoFillIn = F
SolveSystem = 0
HyperbolicPrecond = F
PrecondIter = 10
With these settings I could use rather large timesteps (dt>1e-4) without convergence issues. To reduce the required computational time you can play around with the PrecondIter value that specifies the amount of timesteps the preconditioner is kept frozen.
I hope that helps you!
Kind regards
Jonas
Old   July 12, 2022, 02:24
Vachan Potluri
Dear Jonas,
Sorry for such a late response!
I am really grateful to you for your continuing engagement in this topic. I will try the settings you suggested and get back with my experience shortly.
Thanks again!
Old   July 13, 2022, 01:21
Post
  #11
Vachan Potluri
Dear Jonas,
As you mentioned, I confirm that I was able to use CFL=5 (which corresponds to dt ~ 1e-4) without any convergence issues.
Thanks!
compressible flow, discontinuous galerkin, flexi
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 07:00
Implementing AUSM for FVM and Fully Implicit subsonic compressible flow Krishan.aero Main CFD Forum 6 December 23, 2018 23:13
Inviscid flow simulations in cfx mahdidelfan CFX 1 June 29, 2014 07:14
How to do simulations for pressible flow Gaurav FLUENT 3 October 9, 2003 17:20
