can MPI used in fully-implicit discretization
Like Tree2Likes
  • 1 Post By ZRZ
  • 1 Post By naffrancois
Old   March 22, 2022, 01:19
Default can MPI used in fully-implicit discretization
ZRZ
ZRZ
ZRZ is on a distinguished road
There are many examples of applying MPI to explicit discretization, but can MPI be used for fully implicit discretization?
If possible, how to implement MPI in full implicit discretization?
If not,how to accelerate in Parallel in fully implicit discretization except OpenMP.
Thanks.
aerosayan likes this.
ZRZ is offline   Reply With Quote
Old   March 22, 2022, 02:34
Sayan Bhattacharjee
aerosayan is on a distinguished road
Fully implicit solvers are simple linear solvers.
Look up parallelization of Gauss-Siedel elimination, Least Squares method, etc. Because that's what's used to solve the Ax=b set of linear equations. Rest of the solver is just creating and organizing the matrices.
Those are the two main methods that I know, if you would need names of more methods, I could look it up for you.
Best of luck.
aerosayan is offline   Reply With Quote
Old   March 22, 2022, 05:19
naffrancois is on a distinguished road
You can apply domain decomposition MPI to a fully implicit discretization. As aerosayan said, implicit discretization computational work is mostly about solving linear systems.
This is easier in my opinion with iterative solvers where you usually end up doing matrix-vector products and dot products. Broadly speaking, you work with an extended matrix and RHS containing extra entries associated to flux and flux derivatives at the cpu boundaries. This is a piece of work though, and it should be done very incrementally, starting from pen and paper with a simple equation set.
But short answer yes you can
naffrancois is offline   Reply With Quote
implicit solvers, mpi application
Gradient operator implicit discretization diegon OpenFOAM Running, Solving & CFD 19 August 27, 2022 11:44
Instability with AUSM +upwind discretization scheme ari003 SU2 9 February 7, 2022 01:41
Implicit vs Explicit Method Matteo991 Main CFD Forum 15 June 19, 2020 07:17
Can anybody give a introduction of the term "point implicit" and 'line implicit' ? Tommy Chen Main CFD Forum 2 August 3, 2015 04:30
MPI and parallel computation Wang Main CFD Forum 7 April 15, 2004 12:25
