surface to surface radiation model in fluent
Like Tree1Likes
  • 1 Post By IA1982
Old   March 13, 2022, 19:27
Default surface to surface radiation model in fluent
Abhinay
soankerabhinay is on a distinguished road
I am trying to use surface to surface radiation model in fluent. Radiation tab is only active for fluid components and not solid components. why can't radiation model be applied to solid components? Most problems that involve radiation is related to solids and it doesn't make sense if it only works for fluids.
Note: model does have fluid components and I am using interfaces (non-conformal mesh) between solid and fluid components.
Any info on this is greatly appreciated!
Thanks,
Abe
soankerabhinay is offline   Reply With Quote
Old   March 14, 2022, 04:41
Isabella
IA1982 is on a distinguished road
Fluent 6.3 Radiation Model Theory, Chapter 13.3.7, p. 995. (http://aerojet.engr.ucdavis.edu/flue...f-download.htm)
The surface-to-surface radiation model may be used to account for radiation exchange in a gray-diffuse surface enclosure. The exchange of energy between two surfaces is affected by their size, separation distance, and direction. A geometric function known as a "view factor" accounts for these characteristics.
[from Incropera's Fundamentals of Heat and Mass Transfer, Chapter 13.1 p.812]
F ij is defined as a function of the radiation leaving surface I and being intercepted by surface "j."
soankerabhinay likes this.
IA1982 is offline   Reply With Quote
ansys, fluent
Fluent Radiation Model buckngnr11 FLUENT 1 June 15, 2020 07:46
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Fluent Radiation/porous media Schmitt pierre-Louis FLUENT 26 September 1, 2016 11:29
radiation flux rejected from surface sachin kumar Main CFD Forum 1 June 16, 2015 03:43
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
