reactingFoam aachenBomb OpenFOAM 9
Like Tree1Likes
  • 1 Post By marcosgutierrez
Old   March 13, 2022, 01:08
Default reactingFoam aachenBomb OpenFOAM 9
Marcos Gutiérrez
marcosgutierrez is on a distinguished road
Hi openFoam and CFD users
Do you know how to fix the problem in the pictures.
The part #include "speciesThermo" can not be found.
Any suggestions?
The solver is reactingFoam in OpenFOAM 9
Please see pic 1 and 2.
Thank you
Marcos
marcosgutierrez is offline   Reply With Quote
Old   March 13, 2022, 05:38
Jan Zeriadtke
jerik is on a distinguished road
That error seems to indicate that the file "speciesThermo" is missing.
If you look at the Allrun script in the tutorial, the "chemkinToFoam" application should create speciesThermo.
Therefore check if chemkinToFoam has been run and produced the "reactions" and "speciesThermo" files. If you modified the chemkin files it could point to an error there.
jerik is offline   Reply With Quote
Old   March 13, 2022, 23:22
Marcos Gutiérrez
Dear Jan,
thank you for your answer.
I run "chemkinToFoam" and I got the message in the picture 3.
I also run "./Allrun" and I got the message in picture 4.
I have to make this question: Is there something missing in this solver "reactingFoam" in the "aachenBomb" tutorial of OpenFOAM 9?
I run "sprayFoam" and the "aachenBomb" tutorial in OpenFOAM 7 without problems.
The chemkin files were not modified.
Some other suggestion?
Thank you
Marcos
Old   March 14, 2022, 03:04
Jan Zeriadtke
Hi Marcos,
The output of "./Allrun" is expected. So unless there are further Errors in the logfiles, everthing should have worked.
The chemkinToFoam command needs input and output files specified. For the full command look inside the Allrun script. It should be
runApplication chemkinToFoam \
               chemkin/chem.inp chemkin/therm.dat chemkin/transportProperties \
               constant/reactions constant/speciesThermo
Here "runApplication" just redirects the output to a logfile, so you want everything after that.
Jan
Old   March 14, 2022, 04:03
Marcos Gutiérrez
Hi Jan,
the files are ok as shown in the pic 5.
Is possible that there is bug in openFoam 9?
Marcos
Old   March 14, 2022, 04:31
Jan Zeriadtke
Hi Marcos,
again, from pic 4 everything seems to work. If you aren't getting solution files check the solver output in log.reactingFoam. I verified that the case is working.
If you are very new to OpenFoam i would recommend working through a tutorial case from the User-Guide to get familiar with the workflow. It will be directly applicable to reactingFoam.
Jan
Old   March 15, 2022, 08:59
Marcos Gutiérrez
Hi Jan,
thank you for the commands:
I did not change the chem.inp file and I have the error of pic.8
Best regards
Marcos
Old   March 15, 2022, 09:43
Jan Zeriadtke
Hi Marcos,
check the order of the "chem.inp" and "therm.dat" arguments in the command
Jan
Old   March 15, 2022, 10:14
Cool
Marcos Gutiérrez
Hi Jan,
YOU ARE A GENIE!!!! THANK YOU!!! IT WORKS!!!
Let´s make a summary:
1. Have order and method, do not play with commands, learn and understand how they must be written and used.
2. OpenFOAM doesn't have errors to run tutorials, it may have but a newbie for sure would no discover them.
3. To run the aachenBomb tutorial, open the terminal in the folder where you can see the:
0, chemkin, constant, system, Allclean and Allrun files.
4. Type the following command (it seem to be done only one time):
chemkinToFoam chemkin/chem.inp chemkin/therm.dat chemkin/transportProperties constant/reactions constant/speciesThermo
5. Type: blockMesh
6. Type: checkMesh
7. Step 6 is just for for fun because it is ok, unless you have imported your own geometry.
8. Start to feel the power and the glory.
9. Step 8 is serious.
10. Type: reactingFoam
11. Type: paraview
12. In paraview open the controldict file selecting the option *all kind of files and with the OpenFOAM reader
13. Display the velocities and pressures.
14. There are ways to display the particles with foamToVTK but I will post a clean document later.
15. Say thank you sooooo much to Jan (jerik in CDF online)
Marcos
Expert in reactingFoam
jerik likes this.
aachenbomb tutorial, reacting foam
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
OpenFOAM Training Beijing 22-26 Aug 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 May 3, 2016 05:57
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
