Modelled fluid flow through a packed bed in Python. Output not as expected |
Rep Power: 0 ![]() |
First, apologies if this is the incorrect forum to post on. Its my first time posting here. I checked the other forums and there did not seem to be a more suitable one than this
I have modelled two phase flow in a packed bed using Python. However I am working alone and therefore do not have the option of discussing this with someone. I was hoping to get a second opinion on the short script I have written, as I have clearly done something wrong. My question is - is there a more suitable forum than this one for code help questions like this, or is this a suitable place to have this discussion? I will not add an explanation of the equations/code yet. If this is the correct forum then I will add these. Thank you! Equations used: https://imgur.com/gallery/aXT9KEP Code: https://pastebin.com/vsEr6BRN |
debugging, help for a newbie, porous body, python |
axial compressor mass flow convergence issue | jyotir | SU2 | 5 | July 5, 2024 09:06 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
The udf.h headers are unable to open- in VISUAL STUDIO 13 | sanjeetlimbu | Fluent UDF and Scheme Programming | 4 | May 2, 2016 05:38 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
