Alternating direction implicit (ADI) in square
Like Tree1Likes
  • 1 Post By Continuum
Old   February 12, 2022, 16:39
Default Alternating direction implicit (ADI) in square
Ammar
chberbelali is on a distinguished road
Hello everyone,
I'm in the process of programming ADI method (with Thomas algorithm) for a problem of free convection in a wavy square enclosure, doing the transition from physical domain to computational domain, but my code dosen't support a big range of undulation amplitude and mesh refinement.
Please help!
chberbelali is offline   Reply With Quote
Old   February 13, 2022, 05:34
Continuum
Continuum is on a distinguished road
I’d suggest starting with simple heat equation, no flow, fixed source in order to verify your solver. Then move to viscous Burgers equation, and onward. How are you treating advection terms in ADI and pressure solution?
aerosayan likes this.
Continuum is offline   Reply With Quote
Old   February 13, 2022, 06:51
Ammar
My governing equations composed by two, one for temperature the other for fluid flow, i didn't use Burgers equation!!
Old   February 13, 2022, 06:59
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by chberbelali View Post
Hello everyone,
Please help!
Could you better detail your question? I am not sure about your issue, is a problem of mapping the two domains? Do you have an implicit time step for the diffusion only in vertical direction?
FMDenaro is offline   Reply With Quote
Old   February 13, 2022, 07:34
Ammar
I'm already tested the code in simple case of square, it can't support a large number of iterations (mesh grids), but when i transfom my new domain to make it square it dosn't perfom better.
The new domain: square cavity with a right wavy wall and heated from the left side.
https://images.app.goo.gl/JDDbEFvEvu4ZjTTz9
my scheme:
https://images.app.goo.gl/AshjXZJvs39YHsQa6
adi, cavity, wavy boundary
ERROR: Flow direction on the boundaries must not be tangential to the boundary. turbomax CFX 3 October 27, 2024 07:19
Advective BC with specified direction (outlet-velocity) uckmhnds OpenFOAM Running, Solving & CFD 0 August 19, 2018 21:50
Changing inflow velocity direction deteriorates lift and drag ziggo FLUENT 3 July 24, 2013 09:39
stability of alternate direction implicit scheme thegodfather Main CFD Forum 0 September 21, 2012 06:41
ADI of N-S equations Zhou Yongcheng Main CFD Forum 5 January 18, 2001 08:58
