Najiha
Rep Power: 4 ![]() |
Does CFD air pollutants simulation is categorized as viscous flow?
PENG YAN
Rep Power: 5 ![]() |
Man, just run your simulation as both inviscid and viscous cases, and compare numerical results with paper.
Then you will find which case is better. |
Najiha
Many thanks for the answer
cfd air pollutants, viscous flow |
VISCOUS DISSIPATION at the rotating flow | gaishiwushuang | STAR-CCM+ | 2 | May 4, 2018 13:44 |
set different viscous resistance simulating flow through an anisotropic porous medium | m_chiara_palu | FLUENT | 0 | January 5, 2016 10:11 |
Compressible viscous flow newbie: when NOT to assume incompressible, non-gas EOS? | Srh | Main CFD Forum | 0 | April 19, 2013 02:12 |
Non viscous flow | gat | CFX | 0 | April 10, 2009 05:31 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
