Help with Multall (Fortran77)
Like Tree1Likes
  • 1 Post By flotus1
Old   February 5, 2022, 14:47
Default Help with Multall (Fortran77)
P.B.
combustion_lady is on a distinguished road
I am using an open program called Multall for CFD/turbomachinery design. I have been able to run MEANGEN, STAGEN programs but not MULTALL (with Fortran 77). However, the output files (flow_out and grid_out) that come from running the last program, Multall, are somehow not in the right format. Therefore, I cannot use the last PLOTTING program that requires the two files as input.
The author provides example files for each MEANGEN, STAGEN and MULTALL, but not for the PLOTTING part.
I am wondering if anyone, would be willing to run a simple case on Multall (like a sample case such simple compressor contained in the "multall-test-cases" folder) and post the output files to test the last PLOTTING program and help me understand how to debug this problem.
Thanks,
This is the program I am referencing: https://sites.google.com/view/multal...tem?authuser=0
It can be freely downloaded from the dropbox.
Any help would be really tremendous! only takes a few minutes
These are the steps (Linux)
1. download multall from dropbox link (see above)
2. sudo apt-get install gfortran
3. in the "multall program" folder (located in the MULTALL folder), create a text file called "intype", it must have the single letter N (can also contain O)
4. gfortran -mcmodel=medium multall-open-17.5.f -o multall (a different version can also be picked, this must be run from the multall program folder)
5. ./multall < 3stg-compr+samods-17.5.dat (this file is located in the multall-test-cases folder and should be moved to the the multall program folder before running, there are other test cases, I was hoping to run a compressor one)
That's it! There should be a few output files, but the ones I'm looking for are the two unformatted output files "flow_out" and "grid_out"
combustion_lady is offline   Reply With Quote
Old   February 5, 2022, 15:06
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
I don't quite understand your request.
You were able to run the program, and get the files you need. How would someone else running the program help you?
flotus1 is offline   Reply With Quote
Old   February 5, 2022, 15:26
P.B.
Sorry, I should have been more clear. I can compile Multall, but running fails for me (segmentation). Based on the only thread that I could find on the internet, this is due to "nothing to do with the program" errors that some users get and others don't. This is why someone running the last program (Multall), would be really helpful, so I could at least have an idea of what a typical output looks like for post-processing purposes. I have tried running this with Ubuntu on a virtual machine.
Old   February 5, 2022, 18:13
flotus1's Avatar
Alex
https://www.dropbox.com/s/r5vfwtstmi...st.tar.gz?dl=0
Let me know when you downloaded the data.
The case ran for 7201 iterations and then wrote the output files.
Last line in the shell output indicates some divide-by-zero error though.
 7201  0.0543  45  93  50  0.0005  0.0037   286  275.58  422.61  52  37  41     47.6278     47.7116      1.0018
Note: The following floating-point exceptions are signalling: IEEE_INVALID_FLAG IEEE_DIVIDE_BY_ZERO
The pre-compiled plotting tool "plotall-17.1.x" doesn't run, because some libraries are missing on my machine.
combustion_lady likes this.
Old   February 6, 2022, 08:24
P.B.
Thank you very much for your help. I was actually able to solve the issue, and got the same error at line 7201. The plotting does work for me, but only on Windows with the .exe files.
Old   February 6, 2022, 08:51
flotus1's Avatar
Alex
Btw, I ran a second test with all debug flags enabled that I know of. Set the max number of steps to 20 though.
The same warning occurs at the end, without any additional insight. So the error appears somewhere during post-processing the result, and would require actual debugging effort to get a hold of.
fortran 77, multall
MULTALL turbo compilation Bdew8556 Main CFD Forum 2 August 17, 2020 03:38
colon in Fortran77 jollage Main CFD Forum 4 December 23, 2015 05:55
How can I find a free Fortran77 numerical library? Alberto Main CFD Forum 3 January 21, 2008 01:56
fortran77 help khan Main CFD Forum 3 June 12, 2007 01:24
Fortran77 or Fortran 90 Swapnil CFX 2 November 26, 2002 16:16
