January 2, 2022, 09:01 |
Implementation of a RANS k epsilon solver
David
Rep Power: 6 |
Hello everyone
I want to implement my own code in fortran to solve a RANS standart k-epsilon problem using the Boussinesq approximation. The idea is to get some coding practice as well as to better understand the generall workings of a solver. I then planing to validate my solver using the pitzDaisy case from the tutorial from openFOAM. I understand the generall approach of the turbulent modelling approach but right now I am struggling at the implementation of the different steps to solve this problem. Can somebody recommend a step by step guide/manual on how to implement such a solver? I am especially struggling on how I can solve for the corresponding k and epsilon using transportation equations. Also how can I use the derived Reynoldstress to derive the velocity field? I would love something like: k_new = k_old + dt * parameters. Does something like this exist? And where could I find something like this? Many thanks already in advance for your help. Best regards fidu |
January 3, 2022, 03:13 |
#2 | |
Also, k-epsilon models require wall functions or some specific variant to work at walls. I would suggest Spalart-Allmaras or k-omega for a novice as first implementation. In general, turbulence model equations are not much different from general scalar equations (something you should be really able to solve by yourself before attempting any turbulence model implementation). Some specificities are: - Most models have similar equations, differing the most trough their source terms. Source terms can indeed be relevant, so an explicit approach might simply not work. You should be ready to implement them implicitly. Most models have suggestions on the implicit source term treatment in their original papers - You need first to compute the turbulent viscosity from the turbulence variables before solving the momentum equations, then use the effective viscosity (laminar + turbulent) as constant in the momentum equations. With momentum equations solved, you have the massflux to use in the turbulence equations. Then repeat. |
January 3, 2022, 05:30 |
#3 | |
David
Rep Power: 6 |
I have currently a working code a convection programm for low Prandl number which works pretty well and was thinking to exent/change it for my porpose. However this was a 2D modell where my velocity was calculated using streamfunctions. I then updated my vorticity and temperatur fields using the procedure shown in the images. Thanks again for all your help and time. Best fidu |
January 3, 2022, 06:09 |
Lucky
Rep Power: 66 |
Have you somehow overlooked that OpenFOAM is open source? You can just open up the source code and look at what is there. I realize it is c++ and not Fortran but you can just skip over all the c-specific stuff. There is also a programmer's guide to help you with the gnitty gritty details. If you want you can even compare your streamfunction code with potentialFoam.
Btw k_new = k_old + dt * parameters implies an explicit approach... are you sure you want to do it this way? |
January 3, 2022, 07:41 |
#5 | |
An additional aspect I never looked into is that I expect the turbulence formalism to be maybe different in the psi-omega framework, unless you maybe derive the psi and omega equations from the RANS equations first |
January 4, 2022, 03:21 |
#6 | |
David
Rep Power: 6 |
And thanks to pointing it out with the implized approach. I just wanted to make an example on what kind of manueal/floating charte I am looking for. |
January 4, 2022, 03:23 |
#7 | |
David
Rep Power: 6 |
coding skills.., k-epsilon model, numerical methods, rans modelling, reynolds shear stress |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
Divergence detected in AMG solver: k, epsilon, pressure coupled | Tanjina | FLUENT | 5 | January 13, 2014 10:46 |
Puzzled by multi-block solver implementation...... | Chen Zhi | Main CFD Forum | 3 | February 14, 2010 20:10 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
