Question about staggered grid SIMPLE high Mach number |
December 20, 2021, 21:22 |
Gao Shangya
Rep Power: 5 |
Hi everyone,
my name is Gao. I am now using staggered grid SIMPLE to simulate gas exchange. I have successfully simulated gas flow at low speed (Mach<0.3).When I increase the speed, the results are not reasonable. I have searched some literature and there are some collocated grids with SIMPLE at high speed. But I want to know, it is possible to use staggered grid SIMPLE at high speed. If you can give me some advice, I will be very grateful for your help. |
December 21, 2021, 09:43 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
High Mach flows should be approached using density-based formulations. Usually, non-staggered grid is used. |
cfd, simple, staggered grid |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
Local mach number | jacobH | Main CFD Forum | 3 | October 1, 2014 10:20 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
Question regarding non-uniform FVM staggered grid | quarkz | Main CFD Forum | 2 | June 18, 2011 17:18 |
