how to compare the results of a simulation between two different domains?
Like Tree1Likes
  • 1 Post By FMDenaro
Old   November 3, 2021, 16:50
Default how to compare the results of a simulation between two different domains?
Elena Espana
reespanau is on a distinguished road
Hello all!
I'm working on a CFD simulation applied to the study of turbulence in river reaches. I'm using pisoFoam solver. I run my 3D turbulence model in 2 domains. The first one with a coarse grid and the second one with a fine grid.
I want to quantify the loss/gain of information when we are moving from a fine grid resolution (validated base case) to a coarse grid resolution.
I want to use the velocity field as the variable to quantify this loss or gain of information.
There is a technique to compare these two domains and quantify these differences in the results?
I appreciate your help.
L Espana.
reespanau is offline   Reply With Quote
Old   November 3, 2021, 17:06
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by reespanau View Post
Hello all!
L Espana.
I don't know what formulation you are using but for a generic numerical solution what you need to assess is the grid convergence, that is how the solution change for refined grids. But what you should consider is the h+ step size as parameter.
Only two grids are not sufficient. You can use some averaged velocity profile at different location. But the things depend also on what you are doing (RANS/URANS/LES).
reespanau likes this.
FMDenaro is offline   Reply With Quote
Old   November 3, 2021, 17:43
Elena Espana
Thank you FMDenaro, I'm using a 3D DES model. I agree with your advice. Do you know a tool or command in OpenFOAM or python code to study the mesh convergence?
I appreciate it.
L
University of Texas
How to restart simulation using results from other solver sahmed OpenFOAM Running, Solving & CFD 8 July 5, 2019 07:02
Validation of 2D simulation and experimental results mizzou OpenFOAM Running, Solving & CFD 8 April 4, 2017 10:31
Ahmed vehicle body tutorial RANS simulation gives dubious results denzell SU2 7 March 30, 2015 22:01
interFoam simulation yields inconsistent results for alpha1 surface Ralinus OpenFOAM Running, Solving & CFD 8 January 13, 2014 09:54
simulation results for k-w model and SST model Li CFX 7 June 29, 2007 05:19
