open the analysis solved with ansys in star ccm+
Like Tree1Likes
  • 1 Post By LuckyTran
Old   October 28, 2021, 08:50
Default open the analysis solved with ansys in star ccm+
donkişot
donkişot is on a distinguished road
Hello my friends,
How can i view the post-process part of the analysis at ansys in star ccm?
donkişot is offline   Reply With Quote
Old   October 28, 2021, 14:39
Lucky
Ansys is an entire company. Which part of Ansys are you referring to? Mechanical? Fluent? CFX?
If Fluent/CFX, you can import the volume meshes and otherwise the geometry directly into Starccm using File=>Import=>Import Volume Mesh. You cannot easily import the results. The better way to import results is to export them in the other software and transfer them over through a container like a .csv
Old   October 28, 2021, 20:26
Default Reply
Wise Locks
Janice123 is on a distinguished road
Hello, I found really informative site thanks for sharing!
Regards,
Lynnwood Locksmith
Janice123 is offline   Reply With Quote
Old   October 29, 2021, 05:19
donkişot
Firstly thank you for feedback. I asked this question for fluent. I want export result of ansys and import to star ccm+. Can you explain this subject a little more?
Old   October 29, 2021, 14:20
Lucky
Export the solution data as a csv in Fluent. Import the csv table into Star in tools=> tables.
Watch a youtube video if you're a visual learner and you don't understand what any of that means.
Afterwards, depending on what you plan on doing with the data, you might want to create a data mapper. Seeing as how you are already lost, I do not recommend even pondering what this means until after you've loaded the table into Star but I wrote it anyway to save you time later.
donkişot likes this.
Old   October 30, 2021, 05:02
donkişot
ı will try. thank you for your answer.
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
