Turbulent heat flux in k-epsilon and k-omega
Like Tree1Likes
  • 1 Post By LuckyTran
Old   October 6, 2021, 15:33
Default Turbulent heat flux in k-epsilon and k-omega
Wojciech Gołda
Golaselo is on a distinguished road
Hello everyone,
could anyone help me with turbulent heat flux in k-epsilon and k-omega? I have simple 2D flow in pipe and I would like to include turbulent heat flux in my energy equation. What whould I do, I am a bit beginner in CFD world.
Thanks a lot for help.
Golaselo is offline   Reply With Quote
Old   October 6, 2021, 16:14
Lucky
How are you approaching the flow part? Do you have the laminar energy equation working already?
Really you just replace the thermal conductivity with an effective conductivity using a turbulent Prandtl number. That means you also need a working turbulence model for turbulent viscosity as well. So, the challenge is everything but the energy equation.
Old   October 6, 2021, 16:21
Wojciech Gołda
I am using standard energy equation from Fluent in Ansys. Turbulent heat flux is not included in it. I use two turbulence models k-e and k-w. I didnt change anything else in these models. So I have to modify my wnergy equation and include turbulence heat flux. Can i use udf to do it ?
Old   October 6, 2021, 16:36
Lucky
If you are using Fluent + any turbulence model in viscous model options (i.e. not inviscid and not laminar) then it definitely has a turbulent heat flux and you do not need to do anything.
Sorry I was under the impression that you were working on your own CFD code. I don't know why I would think a beginner would be doing that. Silly me. If only there was an entire forum dedicated to Fluent. :s
sbaffini likes this.
Old   October 6, 2021, 16:53
Wojciech Gołda
So, when I use any of turbulence models, energy equation is automaticly modified and turbulence heat flux is added to it, am I correct? I mean equation number 5 from that:
https://www.epj-conferences.org/arti...2014_02063.pdf
Really appreciate your help, thanks!
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Udf for moving heat flux in 2D cylindrical geometry devia21 Fluent UDF and Scheme Programming 0 April 20, 2015 01:27
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
problem from k epsilon to k omega NJG OpenFOAM Running, Solving & CFD 0 April 15, 2013 09:24
