Taylor microscale from autocorrelation
Like Tree1Likes
  • 1 Post By LuckyTran
Old   August 17, 2021, 11:58
Default Taylor microscale from autocorrelation
luca mirtanini
lucamirtanini is on a distinguished road
Hi all,
I would like to calculate the Taylor microscale. I am reading the Tennekes and Lumley textbook. It seems that it is possible to calculate this Taylor microscale starting from the autocorrelation of the velocity fluctuation, but I am not sure how to do it. Can anyone help me?
lucamirtanini is offline   Reply With Quote
Old   August 17, 2021, 12:42
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by lucamirtanini View Post
Hi all,
You can read Pope to get further infos. A practical technique is to use the fitting of the parabola at the origin.
Have a read also here
https://agupubs.onlinelibrary.wiley....2/2013JA019641
FMDenaro is offline   Reply With Quote
Old   August 17, 2021, 17:51
luca mirtanini
I did the autocorrelation in the time domain. Then I did the parabolic fitting of the autocorrelation, but the fitting curve is not tangent but secant, as shown in the figure. How can I fix this issue?
Old   August 17, 2021, 19:12
The correct procedure is reported in pag 198-199 in the Pope textbook
Old   August 18, 2021, 02:38
luca mirtanini
Ok. Thank you. If I do the autocorrelation of the time history, the taylor microscale is a space scale or a time scale?
Old   August 18, 2021, 04:16
Lucky
If you get it from the temporal correlation, it's the time-scale. Common practice is convert that to the length scale by invoking Taylor's frozen hypothesis
FMDenaro likes this.
Old   August 18, 2021, 05:54
Why don't you simply compute from the spatial autocorrelation?
Old   August 18, 2021, 14:41
luca mirtanini
If I compute the spatial autocorrelation, of data obtained through numerical calculation, I am afraid that the mesh can affect the estimation of the Taylor microscale if the mesh is coarse. I will try it btw
Old   August 18, 2021, 15:30
Of course, I assume you are performing a DNS. Otherwise in any other formulation the computation of the Taylor microscale has no meaning.
Old   August 18, 2021, 17:28
luca mirtanini
I am running a LES. My mesh is coarse, but my time step is short. So, maybe, the time taylor scal can be reliable, isn't it?
Old   August 18, 2021, 21:26
Lucky
It doesn't matter how arbitrarily small your time-step is, the temporal resolution doesn't improve the length scales that is being filtered/resolved by the LES. An LES that resolves down to the Taylor microscales is practically a DNS.
Algorithmically you can still compute the temporal or spatial autocorrelation and do the extrapolation. It's a good mechanical learning exercise if that's what you are trying to do.
Another example is if you did URANS with a super-fine grid. You can follow the steps to calculate the autocorrelation. But you know it is URANS and doesn't have any turbulence in it. It doesn't matter how small your time-step is or how fine your grid is, your velocity needs to be the right kind of velocity in order to get a meaningful autocorrelation in the first place.
Old   April 23, 2022, 06:59
vatan tosun
promise89 is on a distinguished road
How you find microscale from the autocorrelation graph. I have series so Which procedure I need to follow to apply parabolic fitting?
promise89 is offline   Reply With Quote
taylor
autocorrelation and Power Spectrum lucamirtanini Main CFD Forum 23 April 23, 2021 17:39
Offset when calculating TKE using autocorrelation Falu Main CFD Forum 0 February 22, 2021 07:32
Reagrding autocorrelation ari003 Main CFD Forum 10 October 2, 2020 08:32
autocorrelation in Matlab pappo1890 OpenFOAM 5 March 24, 2020 08:22
[OpenFOAM] Velocity autocorrelation and droplet counting coastal593 ParaView 0 March 12, 2008 01:27
