Difference between LES and VLES
Like Tree2Likes
  • 2 Post By FMDenaro
Old   July 31, 2021, 17:05
Default Difference between LES and VLES
luca mirtanini
lucamirtanini is on a distinguished road
Which is the difference between the Large eddy simulation and the Very Large Eddy simulation?
lucamirtanini is offline   Reply With Quote
Old   July 31, 2021, 17:30
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Despite the similar nomenclature, they are fundamentally different in the idea. VLES aims to represent a good compromise between accuracy and computational costs and is more similar to the URANS formulation than a LES. The idea is that the filtering width is much bigger than in LES and the unresolved part are consequently problem dependent. In practice is like an LES code that use a very coarse grid where a small (or disregardable) part of the inertial region is solved in the energy spectra.
Of course, that means that the SGS model is no longer supposed to be universal.
aero_head and lpz456 like this.
FMDenaro is offline   Reply With Quote
Old   July 31, 2021, 17:37
luca mirtanini
How can I know before the simulation if the grid is coarse o fine? If the filter is implicit how can these method be different? Is it a difference that we can do just 'a posteriori'?
Old   July 31, 2021, 17:41
Generally, the filter width is estimated by the parameters dx+,dy+,dz+.
For example, along homogeneous directions a correct LES grid parameter would be O(20-30) while in VLES you could reach quite bigger values.
Have a look to the orgininal Speziale paper about VLES, as addressed here https://www.researchgate.net/publica...turbulent_flow
How to calculate Reynolds Stress using LES data? Jongdae Kim Main CFD Forum 7 February 13, 2020 04:09
LES evaluation help needed RodriguezFatz Main CFD Forum 52 March 11, 2014 08:26
PowerFlow (LBE) vs. Traditional (Navier Stokes)? CFD Newbie Main CFD Forum 44 January 13, 2014 14:56
LES Edward Main CFD Forum 25 September 24, 2001 20:37
Who can suggest some fundamental paper or books for LES or VLES(TRANS)? Jason Main CFD Forum 2 December 16, 1999 00:36
