If RANS are time-averaged then what does timesteps mean in simulations?
Like Tree13Likes
  • 2 Post By EyzehuChacham
  • 3 Post By FMDenaro
  • 3 Post By naffrancois
  • 2 Post By JBeilke
  • 3 Post By sbaffini
Old   July 21, 2021, 13:54
Question If RANS are time-averaged then what does timesteps mean in simulations?
EyzehuChacham is on a distinguished road
Hi all!
I am relatively new into the turbulence modeling. I started with ANSYS and tried to use the k-e model for the first time. The first thing I noticed was the existence of timesteps. This made me confused. If the RANS equations do not contain time derivatives then how do we get timesteps? My initial assumption from a RANS simulation was just to get a result somehow describing the average velocity and pressure in a domain but I got timesteps with snapshots. I googled it for a couple of hours and the best thing I found was URANS, however I haven't specified anything regarding URANS in my simplistic project.
Thanks in advance!
aerosayan and aero_head like this.
EyzehuChacham is offline   Reply With Quote
Old   July 21, 2021, 15:10
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by orkhan78 View Post
Hi all!
Thanks in advance!
Indeed, RANS formulation is by definition for a statistically steady state, what you have to read carefully is the URANS formulation. In this latter, the equations are acted on by a different averaging and they remain time-dependent. However, be aware that the meaning of this time dependence is somehow specific only for the case of external forcing.
In this forum you can find some posts with detailed answers
FMDenaro is offline   Reply With Quote
Old   July 21, 2021, 18:16
naffrancois is on a distinguished road
Not an Ansys user but there are different ways to achieve steady-state solutions. If you discard temporal terms from the governing equations, after spatial discretisation, you end up in solving a (eventually big) system of non-linear equations. You can (try to) solve for it using Newton's method, I highly doubt ANSYS implemented that.
Usually the discretized equations maintain a time-derivative, the objective beeing in the case of a steady-state computation to make it vanish as fast as possible as transient is of no interest. Then time becomes fictitious and is solely used to maintain a stable numerical integration through some stability criteria (CFL<1 for explicit schemes for examples).
naffrancois is offline   Reply With Quote
Old   July 22, 2021, 02:56
Joern Beilke
JBeilke is on a distinguished road
When you go from Navier-Stokes to (U)RANS you do some averaging regarding the turbulent fluctuations. But not every transient effect is related to turbulence :-)
You can have an inlet velocity that changes with time.
EyzehuChacham and aerosayan like this.
JBeilke is offline   Reply With Quote
Old   July 22, 2021, 04:44
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Hi all!
Thanks in advance!
Formally, in the more general sense, the (U)RANS average can be regarded as an ensemble average, over an infinite number of experiments. In the steady case, ergodicity ensures that the result formally matches the time average. For the unsteady case, the formal understanding is that you should only see unsteady effects related to the boundary conditions/geometry, i.e., not stochastic at all.
Some texts relate RANS to the infinite time average and URANS to the average over a time step, requiring the latter to be somehow larger than any dynamic time scale related to the turbulent fluctuations, which can't be unless the unsteadiness really is slow, quasi-steady if you know what I mean.
From a practical perspective, URANS is RANS with the unsteady term. The real problem here is that the turbulence model is not really different with respect to the steady case, besides its own added unsteady term.
We discussed some aspects here (where, by the way, you can also see, in the comments, a link to a work by Prof. Layton that, indeed, tries to cure the URANS anomaly in the model formulation).
sbaffini is offline   Reply With Quote
rans, urans
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 14:47
Time averaged fields on a defined time range Yann OpenFOAM Post-Processing 8 August 7, 2019 05:46
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
