Ansys Fluent (DP 0) Error
Like Tree1Likes
  • 1 Post By jsm
Old   June 27, 2021, 17:02
Default Ansys Fluent (DP 0) Error
aeroriy is on a distinguished road
After Setup, I am receiving this error and cannot proceed to the Solution.
Error:
(DP 0) The Setup component in Fluid Flow (Fluent) requires user input before it can be updated. For instructions on how to address the cell in its current state, click the blue triangle in the lower right corner of the cell in the Project Schematic.
Could you please explain the reason for this error?
Thank you!
aeroriy is offline   Reply With Quote
Old   June 27, 2021, 18:15
Kira
aero_head is on a distinguished road
What kind of simulation are you performing? Changing an angle/value from or to 0 can cause problems depending on the dimension definitions as you may be changing model topology. Also check your time step.
aero_head is offline   Reply With Quote
Old   June 27, 2021, 19:24
I am trying to analyze the velocity and pressure distribution around a helicopter with a defined velocity range(I defined min and max velocity). The helicopter faces the z-direction and I have set the velocity values for x and y direction to 0 and only give a value for z-direction.
I chose the front face of the enclosure(inlet) as velocity-inlet. 10 iterations have been done.
After displaying the velocity graph on setup and save everything I cannot proceed with the solution since the program gives this error.
I googled it and saw some replies like changing the file name, and I changed but seems like there is no difference.
I really don't understand the problem, I hope you can give an answer to it.
Thank you.
Best,
Old   June 27, 2021, 19:27
Thank you.
Best,
Old   June 30, 2021, 04:38
jsm
JSM
jsm is on a distinguished road
Some times this kind of error might happen because of file path with special characters or too long file path.
It is worth to try by moving the file to main drive (example E:\). Otherwise, initialize the solution one more time and start the calculation again.
aeroriy likes this.
With regards,
JSM
jsm is offline   Reply With Quote
ansys, dp0, fluent
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
[OpenFOAM] ParaView command in Foam-extend-4.1 mitu_94 ParaView 0 March 4, 2021 14:46
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
