Boundary layer thickness for turbulent channel flows |
June 14, 2021, 17:22 |
Rep Power: 9 |
Hello people!
does anyone know a reliable empirical approach for estimating the boundary layer thickness in turbulent channel flows similar to that of the flat plates? I cannot afford RANS simulations in this particular application and I need to know the boundary layer thickness based on the Reynolds number and the channel height. Regards, Ryan |
June 15, 2021, 03:05 |
Lucky
Rep Power: 66 |
Maybe you can explain why the information on wikipedia is not what you need: Boundary layer thickness
June 15, 2021, 09:00 |
#3 | |
Rep Power: 9 |
June 16, 2021, 08:57 |
Lucky
Rep Power: 66 |
Square channels aren't that much different than circular pipes.
Away from corners, the rate of boundary layer growth is nominally the same as the flat plate. Only in the corners where the boundary layers of adjacent walls have merged does it deviate and even then the growth is accelerated by only roughly 20% if one continues to use distance to the nearest wall as a metric. If you need more predictive capability than this please specify. I would recommend doing the numerical simulation (but even that might not get you better than 10% accuracy). |
June 17, 2021, 07:35 |
EM
Rep Power: 7 |
What do u mean by "boundary layer"? There is no irrotational
outer flow in internal turbulent flows. suitable bcs near the corner of a turbulent duct flow do not exist. there, the flow has its own unique dynamics and the standard scalings of flat wall-layers do not apply. only thing u can do is apply the standard models using some contrived composite length scale, and hope that the rest of your calculation is not contaminated. such estimates always understate the strength of the secondary velocities and near-corner wall stresses. these velocities and stresses depend on nonlinear instabilities unique to the near-corner flow. -- |
June 17, 2021, 12:16 |
Filippo Maria Denaro
Rep Power: 73 |
The question should be better detailed. Is the inflow in the square channel supposed to be uniform as in the BL theory over a flat plate? If so, you can immagine a first size of laminar development of the BL (far from the corners) before turbulence is developed. That depends on the local Re number.
I am not sure that you can find in literature exactly this flow problem, I remember several papers about rectangular duct but the inflow is different. |
June 18, 2021, 07:02 |
#7 | |
Rep Power: 9 |
June 18, 2021, 07:27 |
#8 | |
Rep Power: 73 |
Well, the lenght is one of the parameters, if the velocity inflow is sufficiently high you can have a fully development. On a flat plate, the transitional region appears at Re_x>O(10^5) |
boundary layer thickness, boundary layer., channel flow |
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 16:15 |
[snappyHexMesh] Holes in internal mesh when adding boundary layer snappyHex | otaolafr | OpenFOAM Meshing & Mesh Conversion | 3 | February 8, 2021 09:19 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 13:41 |
channel half width/ boundary layer thickness | Peter liang | Main CFD Forum | 3 | September 27, 2001 05:10 |
