Heat Transfer in FLuent
Like Tree1Likes
  • 1 Post By LuckyTran
Old   April 8, 2021, 10:36
Default Heat Transfer in FLuent
Mercurial
Techies is on a distinguished road
Hello everyone
I'm trying to setup the boundary condition on heat wall but my experiment data use Naphthalence sublimation on wall to heat. I just know the mass sublimation for heat wall is approximately 20mg.
I don't know how to transfer or calculate Heat flux/Temperature from it.
Does anyone have a suggestion or formulation for calculating this?
Thanks a lot.
Techies is offline   Reply With Quote
Old   April 8, 2021, 16:51
Lucky
I encourage you to read any paper on naphthalene sublimation for heat transfer. If you need one not behind a paywall, here's one.
Presumably, if you scanned the test article, you would have measured the depth of the missing naphthalene. And from knowing how long the test article was exposed, you (using the density of naphthalene) could calculate the mass flux during the experiment.
aero_head likes this.
heat transfer in fluent
Can we use fluent to simulate heat transfer in a solid body?(without fluid) Roh FLUENT 8 January 24, 2019 00:49
Why Fluent give me wrong heat transfer coefficient? mariam.sara FLUENT 10 July 28, 2015 12:28
Heat transfer simulation in electric motor by using fluent thuanckdlvn FLUENT 1 March 20, 2013 07:32
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
