Kira
Rep Power: 8 ![]() |
Hello Everyone,
I ran a simulation and then looked at the velocity profile in CFX-Post and it is not what I expected. I then looked at residual plots in all three planes and I noticed that some residuals were negative (i.e. -5E-10). What do negative values for the residuals imply? Is this an issue? I have searched the forum/online but cannot find anything. |
Arjun
Rep Power: 34 ![]() ![]() |
" I then looked at residual plots in all three planes and I noticed that some residuals were negative (i.e. -5E-10)"
If you are plotting residuals cell by cell basis then they could be negative because res = src - (A . solution) |
#3 | |
Kira
So this is not an issue and would not affect my results, right? |
Kira
I ask because I am trying to figure out why my velocity profile is wrong.
Filippo Maria Denaro
Rep Power: 71 ![]() ![]() ![]() |
Residuals must be evaluated in some norm, the sign is not relevant to ensure the convergence.
Arjun
It will not affect your solution. Most modern CFD solvers now solve the equation in delta form that is first calculate the residual and then calculate the correction corresponding to it.
CFX is just showing you those residuals , same is what starccm does too. |
cfx post, negative residual values, plot, residal |
Problem with blockMesh | cshsgy | OpenFOAM Pre-Processing | 2 | October 2, 2017 11:46 |
[ANSYS Meshing] Small mesh error: Zero or negative volume for elements. [Explicit dynamics] | matin | ANSYS Meshing & Geometry | 0 | September 14, 2017 20:19 |
plot residuals | pigna | OpenFOAM Running, Solving & CFD | 2 | December 19, 2014 02:32 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
What is negative pressure meaning for a head? | Dong Li | Main CFD Forum | 1 | March 27, 1999 21:10 |
